Is 150 shot to much for a SS4000
Old Oct 31, 2010 | 06:59 PM
Its Slo's Avatar
Default Is 150 shot to much for a SS4000
I'm curious if 150 shot is to much for a ss4000. I've shot 175 and 200 on a 4200 converter in a few mustangs I've had. I'm still trying to learn about these LS1's. The car is a 98 Z with LS6 heads/intake, Torquer V2 camshaft, Diamond pistons and 3.73's and the usual bolt ons. Thanks for the help guys
Old Oct 31, 2010 | 10:36 PM
Its Slo's Avatar
tough room
Old Oct 31, 2010 | 10:59 PM
BennyB's Avatar
I would say you would be ok... i personally havent tried, but i know a few that have with good results. I have the ss4000 also, but wont be spraying for another year
Old Nov 1, 2010 | 08:00 AM
TA1364's Avatar
It probably will be fine. I have sprayed a 150 on a pt4400
Old Nov 1, 2010 | 08:09 AM
Noyzee's Avatar
8 second mod
the ss is a little different then the pt (that obvious or they would not mack them) but the ss is set up a little " loose" you could say and isnt the best for spray, but it works ok. we are spraying a car with 100-150 and its ok. not perfect, but ok. check your slip numbers and just be sure its in the right range but you should be fine, just might not get 100% of the performance you could get with the right converter
Old Nov 1, 2010 | 08:59 AM
Its Slo's Avatar
I'd like to stay with a 4k that way it would run good on motor to. I'll most likely start with a 100 and then go to 150 depending on what it runs on 100
Old Nov 1, 2010 | 10:02 AM
Twotonefreak's Avatar
I had 3.73's, 315's and a SS4000 and a 150 shot that did not jive together. I was on the limiter 100ish ft from the stripe. I went back to a SS3600 and it works a LOT better, still a tad loose. I put some 28's on it and it works rather well now.
Old Nov 1, 2010 | 10:14 AM
Noyzee's Avatar
8 second mod
yea, the car we run with the ss has 28" tires on it. runs about 130 mph so far (only made 2 passes with 150 shot and fat as hell)
but with 26" last year and 100 shot it was just before the limiter
Old Nov 1, 2010 | 03:39 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Talk with yank. I worked with him on my stall. He will go over it with you and hes very clear about his opinions.
I do think noyzee has it right. It will work ok depending on your shift point, but will not be optimal.
Old Nov 1, 2010 | 08:15 PM
Its Slo's Avatar
I'll call them and see what they say about it. THanks
Old Nov 1, 2010 | 09:04 PM
Best thing you can do. Yanks is great to deal with. Down to earth and right to the point. On top of that he makes a great product.
Old Nov 2, 2010 | 06:57 AM
gillbot's Avatar
I thought the SS was tighter than the PT, do I have that backwards?
Old Nov 2, 2010 | 05:03 PM
Lt1Porsche's Avatar
I thought the same thing? lol
Old Nov 2, 2010 | 06:01 PM
Detoxx03's Avatar
I'm not too sure about the 4000 but its works fine on my 3600
Old Nov 2, 2010 | 08:46 PM
David Q's Avatar
I know its not the same converter, but I sprayed a 150 on my Circle D 4C+ and it was way too loose for the spray. It was a 4300 on motor and 6000 on the gas. I am picking up new converter tomorrow. I had it brought down to a 3400 on motor and around 4k on the spray. I have always heard a tighter converter works better on the spray.
Old Nov 3, 2010 | 08:51 PM
ASkipper's Avatar
I have a SS4000, I got H/C/I and N2O. I can only spray up to 100hp shot as it gives me a 800 rpm shift extension. If I go to the 150 it just blows through the converter.
Old Nov 8, 2010 | 11:35 AM
Noyzee's Avatar
8 second mod
its been a while, i forget whats what now. lol
