nitrous just stopped working
Old Nov 2, 2010 | 07:23 PM
kidcamaro98's Avatar
Default nitrous just stopped working
The other night I went out to do some runs with my friends and when it came down to using the bottle, my nitrous wouldnt work. Few weeks ago, it worked flawlessly. The car has been sitting outside in cold/wet weather alot in the last few weeks. I checked all the wiring and everything...nothing came lose or anything. I am using the Microedge controller as well. I replaced the Relay, still nothing. Checked all fuses, double checked my controller settings...nothing. I did a quick solonoid check by hooking them up to the battery for 1 second to hear them open, and they opened. Does anyone have any idea's??
I currently have my controller set for testing of the solonoids but they dont work. Early spring I couldnt get my controller to do the testing of the solonoids either but when I was driving they worked.
I am really clueless as to why all of a sudden it just stopped working.
Old Nov 2, 2010 | 07:41 PM
SargeZ06's Avatar
Never mind you said fuse.
Does the MicroEdge power up?
Old Nov 2, 2010 | 07:55 PM
yup. Microedge works flawlessly. The only things I changed the day it didnt work was I set it to spray starting 3rd gear instead of 2nd.
Old Nov 2, 2010 | 08:07 PM
SuperSlow02's Avatar
Might be a window issue, if you have the first version of the microedge you can't test with it. I bet it might be setting that you might of looked over
Old Nov 2, 2010 | 08:51 PM
I bought the microedge brand new from harris speed works early this spring.
Old Nov 2, 2010 | 09:37 PM
SargeZ06's Avatar
Does the screen say "spraying" when it's should be?
Old Nov 2, 2010 | 09:43 PM
it says "armed" when I flip the switch, then it says "trigger" when im WOT
Old Nov 3, 2010 | 05:47 AM
SargeZ06's Avatar
It should say "Spray" or "Spraying" if it was meeting all of the conditions you have set in the controller. It's a controller issue. Probably a setting.
Is it a Microedge +?
Old Nov 3, 2010 | 07:41 AM
its just the microedge...
are you sure on it saying "spraying?" I think it has always said "trigger" even when it was working......
Old Nov 3, 2010 | 09:06 AM
I'm not too sure what it says when it's actually spraying. It does say trigger though regardless of armed or not.
Old Nov 3, 2010 | 09:21 AM
subhumanzz's Avatar
When checking or actually spraying the car the microedge will say *spray* when all the parameters are met. I would say its a setting in the controller if you are sure the electrical is fine. Check the setting for the wot voltage.
Old Nov 3, 2010 | 07:03 PM
are you 100% positive it should say spray???
Old Nov 3, 2010 | 07:46 PM
SargeZ06's Avatar
Absolutely. Mine does.
Old Nov 3, 2010 | 08:15 PM
ok then it sounds like a setting on my controller
not sure what tho.
Old Nov 3, 2010 | 09:08 PM
make sure you didnt change files...that happend to me randomly. Least its a simple fix though man
Old Nov 3, 2010 | 09:59 PM
subhumanzz's Avatar
it says *SPRAY* , yes 100%
Old Nov 4, 2010 | 07:48 AM
I did change files but all my files are setup nearly the same.
How do I set it back to the defaults? I will just reset the thing and re-do it.
Old Nov 4, 2010 | 08:18 AM
SargeZ06's Avatar
Press the "menu" and "up arrow" while you power up the microedge or when you turn on the ignition.
Old Nov 4, 2010 | 03:16 PM
ok thanks alot man!
Old Nov 4, 2010 | 03:26 PM
SargeZ06's Avatar
ok thanks alot man!
No problem. This nitrous group here has helped me a lot. I can't help much I do where I can...
