112 or 116
Old Nov 8, 2010 | 11:40 PM
JUICED01's Avatar
Default 112 or 116
i am wondering what everone is using i have a stock motor on spray on a 150 shot with a standalone i always ran 112 i have 116 in there now just wanting some in put
Old Nov 8, 2010 | 11:45 PM
BarneyMobile's Avatar
I run 116 in my N.O. standalone fuel cell and I haven't had a problem. I checked my plugs to verify correct fueling.
Old Nov 9, 2010 | 12:38 AM
Zero4488's Avatar
Restricted User
Depending on how much timing your running your 112 and 116 is simply wasting your money....I've tuned a number of cars that have a comparable shot to yours and running straight pump with no problems....
Old Nov 9, 2010 | 01:01 AM
camscam02's Avatar
100 octane
Old Nov 9, 2010 | 04:05 PM
Chris@NitroDaves
Guest
Posts: n/a
Everyone here at the shop runs C16 in their dedicateds and we have a ton of customers using C16 in their dedicateds also. There are also several customer's that run between 100 - 110octane in their dedicatd's with great results.
Old Nov 9, 2010 | 07:36 PM
minytrker's Avatar
I always just run pump gas on a 150 shot. C116 is way over kill on a stock motor.
Old Nov 9, 2010 | 08:56 PM
Carter01's Avatar
Pump gas (93 octane) for the 150 shot, #7 plugs. Only recently stepped up to 112 VP Blue when i started hitting it with 200 or greater (#8 plugs).
Old Nov 10, 2010 | 03:55 PM
87silverbullet's Avatar
175 on pump here on stock short block. I think that is the limit though. Needs better fuel with any more than that.
Old Nov 10, 2010 | 05:32 PM
ATVracr's Avatar
We had a 350 shot on Shiz's motor when he won the Pump Gas Drags.
Pump gas burns alot faster than C16 and other race fuels so timing needs to be alot lower and using colder plugs helps also.
