HSW Microedge 6-Speed Settings??
Old Nov 27, 2010 | 09:17 PM
LS1powered09's Avatar
Default HSW Microedge 6-Speed Settings??
Anyone mind sharing your settings?
Old Nov 28, 2010 | 11:15 AM
Gary Z's Avatar
HSW MicroEdge Controller Configuration
Black - Ground
Red - Switched 12 DC Power
Orange - Input from Wideband AFR Meter – Not used
Green - Nitrous Armed Input
Blue - TPS Sensor or WOT Switch Input – Not used
White - RPM Input
Tan - Stage 1 Control
Grey - Stage 2 Control – Not used
Trigger – Off – MicroEdge configured as simple window switch.
Leanout – Off
Delays – 0.0
RPM – Two pulses per revolution.
Min RPM 1 – 3500
Max RPM 1 – 7100 (Fuel Cutoff 7200)
Old Nov 28, 2010 | 11:47 AM
Black - Ground
White - RPM Input
Leanout – Off
Delays – 0.0
Min RPM 1 – 3500
Thanks for the input, but I do have the TPS hooked up as a trigger, mine has a **** load of options and configs, kinda PITA. Keep them coming guys!
Old Nov 28, 2010 | 10:00 PM
LilJayV10's Avatar
I have mine hooked up but that's it. The instructions are kinda intimidating. LOL
Old Nov 29, 2010 | 01:58 PM
Tell me about it! I just opened up a ticket again, hopefully they'll get back to me.
Old Nov 30, 2010 | 02:08 AM
XLR8N's Avatar
if you launch above your rpm limits you need a trigger. the tps should be hooked up to prevent it from activating while being staged.
Old Nov 30, 2010 | 02:05 PM
Brian Coles's Avatar
Help you work on it tonight buddy. Just need to get rpm settings right. If we don't blow it up on first run we'll get it going.
Old Nov 30, 2010 | 02:20 PM
knock on wood bro!
Old Nov 30, 2010 | 09:09 PM
Gary Z's Avatar
You need a WOT switch - using the tps signal is one way of providing a WOT switch. I prefer a conventional mechanical switch (microswitch) in series with the solenoid relay.
Old Nov 30, 2010 | 10:07 PM
It worked! Finally we got a GOOD hit on it, I now just need to drop the pressure on the NANO regulator to 950-1000psi so that the nitrous solenoid will open with NANO on. It's funny how it sprayed fine with the NANO off (after pressurizing the nitrous bottle) but not with it on during a pass. HSW claims their nitrous solenoid only open at 950psi.
Old Nov 30, 2010 | 10:17 PM
Told ya we would get it working. Had to get the settings right. Pulled hard tho when it did spray! Just nedd to get NANO presssure down He got his nitrous smile on tho. That bottle won't last. Ha ha Congrats, welcome to the darkside.
