Asking for trouble to run Nitrous on top of my current setup?
2000 TA 68k miles stock bottom end
TFS 215 CNC cyl heads 58cc
231/237 cam ( possibly going larger, will explain below)
FAST 90/90
pacesetters, ORY, borla
42lb injectors/racetronix pump etc
I have to check PTV, i am pretty sure i will have to fly cut. If by some miracle i dont have to, i will keep my current cam. If i do have to cut the pistons, i am going to go with a larger cam (prob 23x/24x range)
I would like to hit this with a 100 shot, but some people have expressed concerns about spraying with fly cut pistons. Even with the relief cuts, wouldnt the ring lands still be the weakest link? Flycutting aside, would the car make too much power with the 100 shot for the stock bottom end to handle reliabley? Would i be better off with say, a 50 shot?
Opinions, advice etc are appreciated!
. I would love to hit a 130 trap with the added flow and compression of the TFS heads and the 250ish lbs i removed this winter. CHECK PTV...
MS3 has treated alot of people right! It would probably work well if he sticks with his current plan of only spraying 100
