Tuning..
Old Mar 1, 2011 | 04:05 AM
Carlisle's Avatar
Default Tuning..
I'm going to be installing LT's and a custom 3" true dual exhaust here soon, then about a month/month and a half after that I plan on installing a 50-150 wet shot nitrous kit. My question is, when I have the shop tune my car for the headers/exhaust, can I also have them tune it for the nitrous, even though it's not already installed. Just so I can avoid paying for a second tune..
Thanks,
C.
Old Mar 1, 2011 | 07:13 AM
dnkynrbk's Avatar
It depends are you going to get a timming reatard. With nitrous all you have to do is get your NA tune right on then you just adjust your timmingfor nitrous You riching it or lean it by the jets. Get yourself a good wideband to. If you are just do a 100 shot then they can lower your timing accomadate that. If they are a good tunner they should be able to tune it. Then after you get the kit on go back and have them log your car with the nitrous tune when you spray it.
Use the same OCTANE you are going to spray with when you tune and the same plugs. So the tune is not off.
Old Mar 1, 2011 | 08:08 AM
Higgs Boson's Avatar
I'm going to say get everything done at once. Wait on the all the parts and put them on at once and then tune it all at the same time. You can get it close but why? Is your life really going to be different waiting another month to put on your headers??
Old Mar 1, 2011 | 09:25 AM
PGUFF's Avatar
He could go ahead and install the headers, but just wait on the tune. Car will be fine untuned until the nitrous.
Old Mar 2, 2011 | 01:26 AM
Carlisle's Avatar
Hey guys, I talked to one of the shops I was recommended in the area, and asked him about the tune etc. He told me that the best way would be to tune the car for the headers/exhaust, then when I install the nitrous kit, get a controller that when 'armed' will retard the timing. He thinks the controller is plenty for a 100-125 shot, which is all I plan on doing. He recommended 'Harris Speed Works micro edge and interface' nitrous controller, it has things like FPSS and the window switch.
I was planning on going with Nitrous outlet, and I keep think they came with a controller similar to that??
C.
Old Mar 2, 2011 | 12:28 PM
3fingas's Avatar
Pick up a EfiLive or HPT and tune the mods then nitrous. Its real simple. Masport speed's book on efi tuning will get you straight.
Old Mar 2, 2011 | 07:32 PM
Carlisle's Avatar
I don't have the extra 1000$ to put down on tuning software/books, I wish I could, but I can't. So I DO need to tune the computer for the nitrous? A separate controller won't work? Or what?
Old Mar 2, 2011 | 07:53 PM
440LSX's Avatar
if you don't have the money for software, pick up another computer ($100) tune one for spray one for motor. pm me if you plan on going this route i have a 99-02 ecu at the shop
Old Mar 2, 2011 | 09:05 PM
3fingas's Avatar
First off I think the investment would be more like 600-700. You need the ability to pull timing on demand. You can trick iat. Or if your tuner can load a COS5 tune, you can use that to pull, though he would have to make changes if needed. Just makes more sense to do it yourself, whenever.
Old Mar 3, 2011 | 05:41 AM
Carlisle's Avatar
Hp Tuners is 499$, and the books/cd to learn how to use it is 459$. If I did get a tuning software, it'd be Hp tuners. I have a friend that is good at tuning and might sell me his books for less, if he wants to do that, I might consider getting my own software and learning how. It'll sure come in handy seeing as this next winter I'm planning on a 402/408 build. When it comes to tuning myself, well, I'll definitely have to read ALOT because I know almost absolutely nothing..
Old Mar 6, 2011 | 08:20 AM
SuperSlow02's Avatar
Wow..... To the OP, both of those controllers are great and will do what you want. But FWIW I run my nitrous tune all the time. I havnt been able to make back to back passes to see if the 6degrees is hurting na performance or not. But you would also be fine to just install the exhaust now and tune when the nitrous is installed.
Old Mar 19, 2011 | 11:02 PM
hotrodsgmoney's Avatar
C.
Timing Tuner makes a nice controller that's reliable & has all the functions needed unless you want a progressive nitrous controller also.hot rod
Old Mar 19, 2011 | 11:03 PM
I added to your e mail form some info you might want to read
