Need help
Old Feb 16, 2004 | 06:44 AM
Proto X's Avatar
Default Need help
Went to the dyno yesterday and the nitrous would come in and out. It would spray and then cut off. I have a 5177 NOS kit. Anyone know what this could be?
Old Feb 16, 2004 | 02:11 PM
5 Liter Eater's Avatar
Do you have the fuel pressure safety switch installed? If so it's probably that. They have been known to surge like that due to being set too low. You can either omit it or adjust it higher. I have heard to set it, let the engine idle and hook up a test light to it and turn it CCW until the light goes off. Then turn CW until it comes on and then go 3 turns. Not for sure on the three turns though, anyone else?
HTH
Old Feb 16, 2004 | 03:07 PM
SDB's Avatar
SDB
Yeh, the HOBBS switch or a faulty solenoid more than likely.
Old Feb 17, 2004 | 06:35 AM
Proto X's Avatar
Anyone know for sure the best way to adjust this?
Old Feb 18, 2004 | 03:55 PM
Proto X's Avatar
Anyone?
Old Feb 18, 2004 | 04:32 PM
SDB's Avatar
SDB
when I had one on my Vette, I tried to adjust it several times...it seemed to work, and then wham, nothing. I don't know if it got loose or what, but the best way to adjust it is to take it off, smash it with a hammer, and toss hte pieces in the trash, and then take the trash to the curb.
Old Feb 20, 2004 | 10:58 AM
35th SS's Avatar
there you go thats a good one or just get rid of it.
Old Feb 20, 2004 | 11:08 AM
DERTY's Avatar
The Bull
I don't run a Hobbs switch either. The things are flaky as can be. The other thing to look at is if you are using a throttle body contact WOT switch. Just the little flipper switch. I had one on my car, but it would do exactly what you are describing. At rest it would activate, but with the motor running it wouldn't. Seems that it didn't like my motor so I ditched it and went with a electronic TPS sensor WOT switch.
koolrayz's Avatar
I perfer my method of adjusting. I screwed it all the way in. then i screwed it out 3 turns. then i set it on the edge of my computer desk and everytime i read a post about that shitty switch messing up in someone elses car, i adjust it again and thank god i didnt put it in my car
