how much is it to add the whole nitrous kit to my ls1?
how many mpg do you guys usually get??? i am thinking about doing this in the future. say, a 125 shot
This doesn't make any sense.
Nitrous won't effect your normal millage because you only spray under full throttle and in racing conditions. You don't use it at all times like you do a FI set up.
Now I will answer your title. A nitrous kit costs around $700 for a kit and the most common add ons. Window switch and bottle heater are pretty standard.
I too am confused by this question. My initial nitrous kit was $1100. Things get expensive if you want all the goodies. Im bout to add a nano kit and some other things. So total setup im going to be close to $2000. And when using nitrous I figure I get .4 mpg. Estimated of course.
If your wanting a top of the line setup then try Nitrous Outlet..They have awesome kits..If your on a budget then try ColdFusionNitrous..They have a wet kit for LS1 for $499 and comes with bottle/guage/lines/solenoids/relay/jets adjustable 75-100-125-150...All depends on how much u plan to spend and how you want your setup to be.
Guest
Posts: n/a
http://www.nitrousoutlet.com/catalog...3&product=2891
Graham @ N20
You can always do business with us regardless of budget. You don't have give up American made products and the customer service we are famous just because you do not need one of our big direct port systems.
Graham @ N20
Graham @ N20
Guest
Posts: n/a
That is a complete system that can be sprayed how it comes. I would like to see some safety features added to make sure that every thing is good and safe on your car.
But this is true of every system regardless of brand.
Here is what I would like to see added:
http://www.nitrousoutlet.com/catalog...=26§ion=86
http://www.nitrousoutlet.com/catalog...2&product=2552
Graham @ N20
Graham @ N20
