Nitrous problems on a LT1 car, please help!
Old Mar 14, 2011 | 06:48 AM
THADD's Avatar
Default Nitrous problems on a LT1 car, please help!
Ok so the run down on my car is.....383 with a th350 with a 4000 stall. I was spraying a 100 shot through a nozzle and it was picking up right at 100 hp. That was with 4 degrees of timing pulled out. I installed a stand alone fuel system, Nitrous Outlet plate kit jetted for a 225 shot and 6 degrees of timing pulled out. It only picked up 140 hp at the rear wheels on the 225 shot. I know for a fact its not blowing through the converter but I cant figure out where the power is at? It was tuned by a reputable local shop also. Any ideas or things I should try?
Old Mar 14, 2011 | 08:14 AM
Tony Shepherd's Avatar
What spark plugs are you using?
Where was the timing mark on the plug? Visable fuel ring?
What are your cam specs?
What fuel are you using?
Old Mar 14, 2011 | 08:39 AM
THADD's Avatar
I am running NGK 8es. The timing mark is all the way at the base of the tip(closest to the threads). You cant really see it at this point. I am running 112 in the stand alone tank for the nitrous and 93 in the main gas tank. As far as my cam I cant remember the specs right off. It was picked by engine builder. The only thing I can remember is the lift is in the 580 range. I know that is vague
Old Mar 14, 2011 | 08:52 AM
If your timing mark is that low down on the strap you may have too much timing. Could have slight detonation which kills power and will eventually kill your engine.
Kinda need to know the cam specs. Some cams with a certain overlap and LSA work well with small shots of nitrous but the larger shots it can literally blow the excess out of the exaust.
Example. 242/244 580/580 108 lsa this cam will only work well with a small shot.
What is your compression? That plug may be too hot for a 225 shot.
Old Mar 14, 2011 | 10:13 AM
THADD's Avatar
The compression is 11.4:1. I will get the cam specs and post them up. So maybe a colder plug could help? What do you suggest?
Old Mar 14, 2011 | 10:20 AM
That heat range of plug should be about right for that size shot with your compression ratio.
How did the engine sound when spraying? Was it popping out of the exhaust by chance?
Old Mar 14, 2011 | 10:33 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Also what was the exact jetting and Fuel pressure? I agree that its sounds very aggressive on timing.
Graham @ N20
Old Mar 14, 2011 | 10:44 AM
THADD's Avatar
It is a .082 nitrous jet and one size smaller than the matched fuel jet on a 10psi system. I hope I am making sense here. The car sounds great, it is smooth and clean during the run. It just runs like a car that has a 150 shot or so and not like one that has a 225.
http://www.youtube.com/user/97HITTMA.../0/4L4-YgvahH8
Here is a vid of the pass
Old Mar 14, 2011 | 12:27 PM
a4ls2goat's Avatar
what MPH are you picking up from motor to nitrous
Old Mar 14, 2011 | 12:46 PM
THADD's Avatar
about 8 mph
Old Mar 14, 2011 | 01:36 PM
Gap the plugs at 32 , Pull two more degrees, and start reading plugs from there.
Old Mar 14, 2011 | 01:43 PM
THADD's Avatar
Ok gotcha. They are gapped at 30 right now. Thanks guys for the help. Anything else anyone has to add by all means please do so.
Old Mar 14, 2011 | 02:32 PM
If they are at 30 that is fine.
Old Mar 14, 2011 | 02:41 PM
a4ls2goat's Avatar
filter not clogged? what bottle pressure?
Old Mar 14, 2011 | 03:55 PM
THADD's Avatar
The bottle pressure is always between 950-1000
Old Mar 14, 2011 | 11:26 PM
singlesupra's Avatar
I agree Thadd, definatly try to get the timing where it should be first and foremost.
Old Mar 15, 2011 | 06:28 AM
THADD's Avatar
I am going to the shop tonight and pull a few plugs just to make sure what I am telling you guys is correct on the timing. I know that we are pulling 6 by my Hyfire box but I want to check the strap and see where the timing mark actually is. I will post on this later tonight
Old Mar 15, 2011 | 07:44 AM
You can only check the timing mark immediatly after a run. Make the run and kill the engine, coast to a safe spot and pull the plugs. If on the dyno, make the pull and kill engine immediatly.
Old Mar 15, 2011 | 08:02 AM
THADD's Avatar
Ok then I should be able to hit it in the street on gas then shut it down and coast to my drive way
Old Mar 15, 2011 | 08:13 AM
Just make sure and hit it for more than 6 seconds to get some heat in the plugs.
