help with deciding how large off a shot
Old Mar 20, 2011 | 11:46 PM
Brandon331's Avatar
Default help with deciding how large off a shot
I have a full bolt on 6 speed car with nitrous I am looking at spraying a 150 to 200 shot would a 200 shot be to much or can a stock ls1 bottem end handle it?
Old Mar 21, 2011 | 12:24 AM
a4ls2goat's Avatar
itll take 150 shot all day with a good tune up
Old Mar 21, 2011 | 08:55 AM
Graham@NitrousOutlet
Guest
Posts: n/a
How I typically explain it to people on stock bottom ends is this. 150 is where you still have some safety margin. If you want to go to 200 we need to talk about your tuneup, is this a daily driver, and can you afford to fix a motor is you happen to hurt it.
A few safety features can really help parts survive along with allowing us to help keep the tune dialed in.
Graham @ N20
Old Mar 21, 2011 | 09:07 AM
Brandon331's Avatar
its my daily driver for another month then its sitting for a 6 months im picking up a window switch and a progressive controler ect. i have heard off people running a 200 shot on stock bottem ends with alot off tuning i was just wondering how long it realy last b/c i dont want to replace the motor after the 2nd or 3rd run
Old Mar 21, 2011 | 09:09 AM
Guest
Posts: n/a
With our progressive you will not need a separate window switch. Give me a shout when you get a chance. I will get you lined out on some parts and we can go over what it takes to make a 200 shot last.
Graham @ N20
Old Mar 21, 2011 | 01:42 PM
Brandon331's Avatar
allright i will when i get free from work tomorrow
Old Mar 21, 2011 | 07:39 PM
Carter01's Avatar
You're doing the right thing, Nitrous Outlet will get you sorted out. FWIW many of of spray 250 on stock motors frequently. It can be done but research and listening is your best friend. Good Luck and shoot me a pm if you have any further questions....
Old Mar 21, 2011 | 08:32 PM
Guest
Posts: n/a
Carter here is a perfect example. He learned a lot very fast. Took his time with his tuneup and now look at him. Plug reading like a pro and spraying a stock bottom end into the 9's.
BTW your recommendation has brought a few people are way for not just parts but also to get some solid tech. I appreciate the support man. It shows when we get call's from people that mention your name.
Graham @ N20
Old Mar 21, 2011 | 08:37 PM
Carter01's Avatar
Graham @ N20
Thanks Graham, keep treating them right because I send them all to you guys!
Old Mar 23, 2011 | 07:16 PM
mitch g's Avatar
just do the 150
Old Mar 23, 2011 | 07:49 PM
a4ls2goat's Avatar
carter01 is very knowledgable.... keep up the good work man!
