should i go with gauge on bottle or auto meter gauge in pod
Just wondering is one more accurate then the other i know having it in a gauge pod is easier to see.....Also how do u hook the auto meter up do u just run a tee off it and have the feed line going in and then back out to the solenoid?
running a gauge on the bottle will be the easiest and most accurate but if you have the bottle hidden then you will have to run a pod gauge. the bad thing about running a gauge in a pod that you will end up wasting a lot of nitrous every time you open/close the bottle because it has to fill up that line every time, so if you are going to go that route go with an electronic gauge
Can u just run a tee in the line and have the tee connected the actual gauge...Am i making sense lol that way the main feed line keeps going to the solenoid just has a tee in it a guage and i will have a shorter line coming from tee to solenoid cuz i dont wanna run two main lines as mentioned and i already got auto meter gauge but not the bottle gauge trying to make what i got work lol
Mines an auto meter but it was gave to me i wanna put it in the console as with my switch panel i want the car to look as stock as i can on the inside as least lol. I would get an electric if it was up to me but im trying to save my funds for other stuff! but i will get a gauge on the bottle as well just to be safe they cant be to much
I just did this in my car. I will try and get you a pic today. I couldn't see the bottle gauge from the driver seat so I decided to go with an autometer gauge in the a pillar. I used a fitting from nitro daves that has two NPT ports in it. That way I could run my bottle heater safety switch and the sending unit for the gauge on the same fitting. I'm very happy with the way it turned out.
I have my gauges at the bottle to look at went it not open for in the summer. then i have my nitrous senders at the solenoid to read the bottle pressure. I like knowing my pressure at the solenoid before it goes in the engine, My bottles are in the back so i get a little pressure drop over 16'
