Safe to spray a high mileage stock block?
I have a cam-only 2000 Z28 with 138k miles on the clock.
I was thinking of doing a head swap, but now I'm thinking nitrous.
I already have a bunch of stuff to install:
Now I'm contemplating a 100 dry shot via Halo Kit & NANO 3000.
The car currently makes 366whp (Mustang). After inductions mods above, I expect to make around 380whp. I'm pretty sure a 100 shot w/ NANO would put me around 470-480whp.
Does this sound too risky for a high mileage stock block?
I have always kept the revs below 6400 and plan to keep it that way.
Thanks in advance.
- 42lb injectors
- Pro Products 96mm Typhoon Intake
- Pro Products 101mm Throttle Body
- Fast Toys 104mm Lid
- TSP 100mm MAF
Thanks in advance.
My camaro has 170,000 miles on it and I spray 125 wet shot with no problem and it loves it. Just buy the right plugs and all the saftey stuff and you should be fine. The highest I would go is a 150 anything above that your asking for trouble.
x2, i only spray a 100 shot, got it put on the other day and i love it, 176k miles
Here's the sticky:
https://ls1tech.com/forums/nitrous-o...o-read-me.html
And here is the section I'm referring to:
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
Nitrous (one step colder)
Heat Range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
Nitrous (two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK B8EFS 1049
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Heat Range: 8
Gap: Consult
Here's the sticky:
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Heat Range: 8
Gap: Consult
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Heat Range: 8
Gap: Consult
i have no hard facts to post to prove it but in the nos tuning guide it says up to a 100 shot of dry that on gm ls applications you are fine with stock timing and fuel but may want to drop in the heat range as a big safety precautiion.
