Pieced Together Kit - What Jets?
I thought I may start with Zex's chart since they are always on the rich side.
Next question, as you change timing will the timing mark on your spark plugs move?
This is on a 6.1L Hemi by the way. Sorry to be an imposter but there's a lot more knowledge over here.
Thank you.
Thank you.
Start with Harris jetting. Make sure you are running the correct plug for the shot size and also pulling more timing than you think you should, again for the respective shot size.
Especially with this system you need to put fresh plugs in. As little drive time as possible. Make a pass and shut it off. Pull all 16 of those plugs. If you are not familiar with plug reading. Pull them. Put old ones in to make the drive home and I can help via pictures.
When I dabbled in turbo cars there was always a concern of excessive EGT's with excessively retarded timing. Is that not the case with a nitrous car?
