damaging effects of nitrous?
Old May 27, 2011 | 04:29 PM
KFZ)^'s Avatar
Old Jun 3, 2011 | 07:50 PM
custm2500's Avatar
Ph.D. in HUBRIS
Only damaging effect of nitrous if used correctly is to your opponents pride and reputation.
Old Jun 3, 2011 | 09:03 PM
got-a-ls1's Avatar
this is what kills motors... normal nitrous setups will be fine..
Old Jun 5, 2011 | 11:04 AM
kevindglenn's Avatar
Judging on what I've researched, and seen in a particular Chris Farley movie, the only real damage that can occur is if the line ruptures and you may find yourself in hysterics.
Old Jun 11, 2011 | 03:07 PM
L92 fox's Avatar
I have never laughed so hard after the last few posts.
I know a guy that sprayed a 175 dry shot before he maf on his completely stock 98 Camaro. I believe it was running high 10s. It had close to 200000 miles and then it finally let go due to a cracked 7 piston. The bearings still looked brand new.
Old Jun 13, 2011 | 05:20 PM
Carter01's Avatar
Originally Posted by ElkySS
my bottom end is all forged with rings gapped for nitrous. im going to be adding a nitrous outlet plate system and i keep hearing it will tear up my motor even if i dont have catostrophic failure. any truth to this? im not gonna lie, im scared of nitrous. i know i shouldnt be but i wanna learn all i can before actually using it
If you are willing to do the research you can spray safely for a long time with the listed motor. I run a stock motor minus cam shaft and use a .088 jet or 250 shot. If i had what you have I would be spraying 350 or greater. I actually plan on spraying 300 this fall but I need more safety equipment first. If you built the car to run then run it
Old Jun 14, 2011 | 12:12 PM
ElkySS's Avatar
i also built it to daily drive. lol
Old Jun 17, 2011 | 06:23 PM
blakez28's Avatar
Originally Posted by speedgoat
I want NOS but I be scerd too. I saw this movie where these 2 homie's ended up on the wrong side of town and some aisian gangsters jacked them and shot up their eclise with NOS and the car blew up yo. Last thing I want is my camaro blowing up if gangsters roll up on me with automatic weapons...
wondered if a Fast and Furious was going to make this thread lol
OP don't worry you can spray no problem. Like previously stated just have a good tune, and drive like you've got some since. Don't spray above 4th gear, under 3,000 rpms, pull the appropriate timing, get the right plugs, and stay away from that limiter.
Read the sticky and search ls1tech and you'll fine lots of nitrous stories with do's and don'ts.
Turn the bottle off when aren't spraying the nitrous, don't leave the bottle in the car on a hot day, and it wouldn't hurt to get a purge, window switch, and some other goodies. just some quick ideas off the top of my head
Old Jun 18, 2011 | 06:16 AM
Joinedthedarkside's Avatar
and if they tell you the first time to stay out of their neighborhood then dont go back the second time with a goofy white boy
Old Jun 18, 2011 | 11:46 AM
Detoxx03's Avatar
You will be fine with your built motor. Pull the correct amount of timing and get a good tune.
Old Jun 19, 2011 | 12:21 PM
ryarbrough's Avatar
Ignorance has killed far more motors than nitrous has.... Ask the right questions and rely on good sources of information and you'll be in good shape...
Old Jun 19, 2011 | 02:14 PM
  #32
curiousGeorge19's Avatar
ok so i am a noob to nitrous... what exctly do u mean by getting a proper tune for nitrous. Does that mean going to a professional tuner and having a full map, or just a stand-alone or piggyback system installed? I am looking at possibly spraying my ls1, and i am trying to learn as much as possible before i make the jump.
Old Jun 19, 2011 | 02:32 PM
  #33
ElkySS's Avatar
they mean dyno tunning.
im not too much worried about the nitrous itself as much as other parts of the motor failing. like a few weeks ago, i bent a bunch of pushrods at wot and it started missing real bad. or what if my opti decides to start scattering spark? **** like that
