how big of a shot on 93 oct pump gas
Hi
wondering how big of a shot is save/possible to run whith 93 oct pump gas?
Setup
plate kit
C5 vette 404ci 11.4:1 CP 248.254 @114+4 CAM
i have both set of 7īs and 8īs plugs
and i use HPT for tuning whith wideband
Baezi
Setup
plate kit
Baezi
Guest
Posts: n/a
In the 200-250 Range. What is the goal here? Certain ET? What have you sprayed before on this combo?
By the way if you wanting to spray a plate at the edge of octane you might want to get a few more plugs.
Guest
Posts: n/a
People have done up to 250hp with 93octane gas but i personally wouldn't go that high on just straight pump gas. Now if you can mix 5 or 6 gallons of race gas in teh tank then i'd say definitely go up to 250hp but if not i'd stick around the 200hp mark and have fun with the car.
Hi i have never sprayed before... my first summer on NOS iīm gona work my way up...
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
But tell me iīve been searching here alot and people are talking about itīs all about tuning how big of a shot you can go, so tuning is not the issue here but are they meaning the timing only or is it fueling also that needs to be adjusted to on bigger shots ??
should the AFR be in the same range as NA??
I have standalone cell, but offcourse i would run race gas in that.....
but the reason for this thread is there are trackdays here that i would like to compete in that hava a limit, itīs (pump gas and DOT tires).
so i would not be able to run race gas there only 93 oct.....
thanks
Baezi
Guest
Posts: n/a
Both. Tuning is not just one thing. It's plugs, tune, Etc.
No. It should start in the Mid 11's. From there you tune off of the plugs.
thanks
Baezi
Nitrous tuning is more simple than some make it out to be. But pushing the edge of anything is not easy, especially octane. Since you had to ask such basic questions here (Which is very smart to do.) stay conservative and get help from us or a knowledgeable user. This will help keep parts alive while your still getting up on the learning curve.
Baezi
ok i already tested .078 jet last summer both on 93 oct and on racegas, but now iīm plannig on jetting it up next season
if i run .085 jet on 93 oct pump gas what plug should i use?
there is one competition per year King og the Streets and the rules are DOT tires and pump gas , other then that i will always use racegas.
Baezi
yea offcourse, but there is this one race per year KOTS and only pump gas so i need to tune specially for that one and i was thinking what plugs to go whith on 250-300 and pump gas
i ran br8īs plugs on .078 jet
Baezi
