how much can you spray on pump gas?
I'm looking at around a 250hp jetting. is it possible to run 93 pump gas in the tank? I have sprayed 200 before but 250 seems not a good idea. I'm tossing the idea around of putting a 1gal fuel cell where my battery used to be and get an inline pump and run race gas to the fuel side of the nitrous kit but run the motor on 93 pump gas. Others tell me mixing fuels is a bad idea, but We have already done this fuel cell setup mixing 93 and race gas on a carbed monte carlo on a friends car with no problem on a 325shot. I just want to be safe on my LS1. what kind of setups do you guys have? what do you recommend for the correct way to run fuel to a 250 shot?
You can spray alot but why?
Been to the Pump Gas Drags with 2 cars and won it once.
We only did it because those were the rules.
If you can put race gas in it, do it.
Your friends Monte Carlo probably doesnt have a 15* head on it. (larger tuning window with old crappy heads)
My suggestion would be get stand alone put some C16 in it.
ya it was a 406 with some 23 degree heads. I'd like to go with the safest route so I'll prolly go with a stand alone fuel setup then. what size fuel cell did you use for your setup? where is the best place to put it on these cars? I assumed it would fit behind the headlamp where the battery used to go.
Not only will the stand alone be much safer, you can run more timing with the stand alone and race fuel.
It is cost vs. need/need in my eyes. Stand alone is highest cost but safer and more power. Running race fuel in the tank is fairly low cost but not an exact science and running 93 is clearly cheapest but going to be bottom of the totem pole.
I don't understand the deal with people saying the standalone with c16 is going to save your ***... Have you ever took the time to think about the combustion chamber and what your feeding it with? Ok so your motor is running on 93 octane, making 4,5,6,700hp on motor so your fueling the **** out of it, your saying that squirt of c16 out of that nitrous nozzle is going to over ride the 93 the cylinder is fuel of powering the motor??
I guess in plain words the amount of 93 your powering your motor on at WOT is not going to be quenched by the squirts of c16 your spraying in the same cylinder your your cars injectors are spraying in.
My two cents, drain the car on the day your going to the track and fill the tank and the standalone with c16. If you can afford all the cost and needed equipment to safely spray your car on the high ends of 250+ hp nitrous you can't tell me throwing 10gallons of c16 in your gas tank is going to break you.
The standalone is great for being an independent fueling pump and supply but IMO it does not make your motor safer to spray with on pump gas....
Thanks for hearing me out
However there are countless guys here running 150-175-200 shots on pump 93. So, in essence that is where the "cushion" has been taken away and you must add in more octane to keep detonation away hence the standalone with c16 in it. So, the c16 is for the rest of the big hit you are trying to spray, giving you more "cushion" to keep detonation at bay.
Guest
Posts: n/a
The standalone setup is a greatly proven way of running the bigger shots. If it wasn't working people wouldn't be doing it over and over again. Plus this way, IF you wanted to squeeze it on the street, then you can
I drive the car on hot rod power tour every year and that is a great example why i'm building the bottom end to run on 93 pump gas. we drive hundreds of miles and then stop at a track where I would be spraying the car. The stand alone fuel setup for the nitrous sounds like the perfect solution for me so I can drive all over the place on pump gas and when I need to spray I have c16 in the fuel cell ready at any time. As long as its proven to be safe I'm definetly going this route.
Guest
Posts: n/a
