Timing controller options
Old Sep 19, 2011 | 08:34 PM
jcob's Avatar
Default Timing controller options
Hey I'm planning on purchasing something to pull timing out when I spray it. I know msd makes a timing twister and have heard of a lingenfelter making something doing the same thing but wasn't sure what everyone thought was the best or what other options there are for an ls1.
Old Sep 20, 2011 | 05:02 PM
Dave_the_SS's Avatar
Hsw
nitrous outlet
and yes lingenfelter makes the LNC-002
to my knowledge the HSW and the onlygenfelter lnc-002 are the only 2 controllers that when activated will show on HPT.
i just purchased the HSW interface and will be installing probably this coming week. i'll get back to you with what i think about it
Old Sep 21, 2011 | 12:57 PM
89pigeontoe's Avatar
Not sure on your setup but on a different car i had msd multi-step retard, 4 stages allowing to pull 9* in each stage. Burnout, come up on convertor with timing, then release trans brake, timing is pulled, nitrous comes on.
Old Sep 21, 2011 | 01:36 PM
Nitro Dave's Nitrous Outlet's Avatar
On my race car I use the Custom operating system with EFI Live.
On my wifes 2010 camaro I used the lingenfelter up until we sold the car.
We do installs here at the shop and we have used the timing tunner for race tronix as well as the MSD Timming Twister.
In my opnion the Lingenfelter using is the best choice.
It can remove up to 15 degrees of timing. It has a two step built in. It simply plugs in between the coil pack connectors. and it is the only unit that has a 0-5 volt refference wire that allows you to use HP tuners, EFI Live or a volt meter to varify the unit is removing timing.
Dave
Old Sep 23, 2011 | 12:04 AM
jcob's Avatar
thanks for the inputs. i just found a guy selling a timing tuner locally for a good price i'm gonna try it then if i'm not happy with it i'll try the lingenfelter. mine has a 98 pcm so i'm not sure if i could run a custom operating system.
Old Sep 23, 2011 | 03:37 PM
You would have to swap to a 99pcm for the custom operating system. The timing tuner will work fine. I have used many of them before the lingenfelter came out.
Dave
Old Sep 24, 2011 | 10:59 AM
SargeZ06's Avatar
<Sarge whispers> Resistor Mod FTW! Let the PCM pull the timing.
Old Sep 24, 2011 | 11:55 AM
Detoxx03's Avatar
MSD Timing Twister here
By Brett Foote | 2026-06-04 05:00:17
