Nitrous before a cam?
Old Sep 23, 2011 | 12:44 PM
Rise of the Phoenix's Avatar
Default Nitrous before a cam?
I'm really new to the whole Nitrous scene, so bear with me. I've got a 02 WS6, M6 that has long tube headers, true dual exhaust and SLP lid. I'm thinking about adding a Nitrous plate system to the car, but want to know if I should do a cam before the Nitrous? My plan is to eventually add a cam, so would doing Nitrous first be a mistake? Thanks for the help guys.
Old Sep 23, 2011 | 01:42 PM
custm2500's Avatar
Ph.D. in HUBRIS
Nitrous will be just fine before the cam. Unless you are getting into big shots 250+ cam choice is not effected much weather you are on nitrous or not.
Juice it and you will be happy.
Old Sep 23, 2011 | 03:35 PM
That's kind of what I thought, but wanted to make sure. I don't plan on spraying more than a 150 shot, but once I get a cam, I'll probably drop it down to a 100 shot due to having a stock short block.
Old Sep 23, 2011 | 10:19 PM
owndjoo's Avatar
you'll be fine running the cam and 150 shot. and yes if you want to do nitrous first, it'll be a much easier way of adding a lil oomph
Old Sep 26, 2011 | 04:44 PM
manfred717's Avatar
Nitrous is deffinitely more fun, then add the cam later!
Old Sep 26, 2011 | 08:20 PM
89pigeontoe's Avatar
Spray that bad boy
Old Sep 27, 2011 | 08:41 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Originally Posted by manfred717
nitrous is deffinitely more fun, then add the cam later!
+1
Old Sep 27, 2011 | 10:20 AM
Thanks guys. Going to go for it. If you can, check out my other post as well. I've got more questions that I bet you guys could help me out with.
Old Sep 28, 2011 | 02:26 PM
BobDoLe's Avatar
nitrous first..
Old Sep 28, 2011 | 06:15 PM
TA1364's Avatar
200 shot first
