Which plugs should I use???
Old Nov 27, 2011 | 10:12 AM
Benny Tocamelo's Avatar
Default Which plugs should I use???
I'm going to be installing an HSW 78mm wet plate kit and spray a 150 shot. I have TR55's in now but don't know if I should go one or two steps colder. Which plug should I use? Engine mods are in my sig.
Thanks in advance!
Old Nov 27, 2011 | 11:15 AM
Carter01's Avatar
br7ef at .33-.35 should be fine on 150.
btw- we have very similar mods, you have low 10 sec potential if not high 9s.
Old Nov 27, 2011 | 01:05 PM
Thanks for the info man! Congrats on he mag article!
I'm still on the stock 4l60 or 10 bolt rear for now so I don't know how realistic those times will be. I plan on taking it easy out the hole with the spray till I put a good Trans and rear in.
Old Nov 29, 2011 | 02:23 PM
KING Z28 HAWK's Avatar
Yeah the 7's will be good. I'm with you on the sissy 4l60 mine is slipping with only full exhaust. I get my performabuilt in Feb! Just enough time to get ready for March Meets.
Old Nov 29, 2011 | 06:31 PM
doubleD_white_t/a's Avatar
I am running tr6's in mine with a 150 shot
Old Nov 29, 2011 | 09:41 PM
87silverbullet's Avatar
I guess you like taking chances then.
Old Nov 29, 2011 | 09:49 PM
The br7's were all white and not healthy looking when i pulled them out...
Old Nov 29, 2011 | 09:56 PM
That means your tune is off. Make another thread and post some pics of the plugs.
Old Nov 30, 2011 | 12:32 AM
I am reading up on reading plugs right now lol. I realized about 30 minutes after i posted that what an uneducated post it was.. I am gonna get some fresh plugs tomorrow and get to reading.
I have been told a couple of different things though such as the br7's are too cold and when i saw these i just assumed that was the case. Woops on my part.
Old Dec 2, 2011 | 05:31 AM
slammin86's Avatar
Br7's are fine. I ran them without problem for over a year and a half. I had planned to up to a br8 or br9 for a 200 shot but then sold the nitrous. I wouldn't even consider spraying on a tr6. Sure it might work, but with how cheap plugs are why even chance it?
Keep in mind when you start swapping plugs around it is a good idea to have the car logged to make sure the trims are in check and it did not throw off fueling too bad. At a minimum check WOT AFT with a wideband.
