Went a little faster today, vidoes included!
Your car will pick up for sure with a NA converter. I say spray it before you change converts tho and post up the 8sec slip.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Thanks guys! It is truly incredible what these motors will take. I learned a valuable lesson this weekend when it comes to timing and reading plugs. I thought I had a pretty good grasp on reading plugs but it goes to show you that you never stop learning if you want to go faster.
#37
We finding out how much weather plays into starting line HP, even with a ton of timing pulled out on the starting line when the air gets good its an animal.
Pull another one and maybe try leaning it out a little with it out.(depending on the air of course)
![Suspicious](https://ls1tech.com/forums/images/smilies2/suspicious.gif)
![Crazy](https://ls1tech.com/forums/images/smilies2/crazy.gif)
![Bat Angel](https://ls1tech.com/forums/images/smilies2/bat_angel.gif)
