N2O Cam Question
Old Nov 15, 2001 | 11:11 AM
cantdrv65's Avatar
Default N2O Cam Question
Alright guys I'm looking for a good N2O cam that is going in my daily driver. I'm going to be running the TNT 150 shot on top of it along with Mac hearders and other boltons. Stock cubes, stock heads. I'm debating between a comp 218/224 .563/563 112 or 114 LSA and the Gm hotcam. What are your opinions on the better cam or a suggestion on any cam? Also, would a 112 or 114 LSA be better suited for N2O use???
The car is an '99 Z28 M6 with 3.42 gears.
Old Nov 15, 2001 | 02:32 PM
RyanJ's Avatar
SSU Moderator
Default Re: N2O Cam Question
i heard the 112 is good because it does not build as much cyl. pressure with the low LSA. a T1 (221/.558/112) ALWAYS works well with MN6's. Just get a HPP3, drill the tb a bit, and haul ***.
oh... a local guy went 11.4's with a t1, macs, and a hidden 100 or 125 shot. (drag radials i think)
Ryan
[ November 15, 2001: Message edited by: RyanJackson ]</p>
Old Nov 15, 2001 | 03:52 PM
RyanJ's Avatar
SSU Moderator
look in the engine section. there is a good discussion on cams for n2o and FI
Ryan
Old Nov 15, 2001 | 08:29 PM
N2O Guy's Avatar
I would go with a cam that favors the exhaust duration 10 degrees @.050 and .010-.015 on the exhaust. 112 is a good lsa for spray. I would have to see your flow numbers at the various lifts to help more but as long as you get somthing in there that has the same amount of lift as your heads peak flow you will be good. also remember that what we are trying to do is fill the cylinder with as much spray as possible so you will want a cam that pops the valve open at just the right time so your air speed is at its peak. Th e trick is to have it aggressive enough but not overly aggressive..The later will eat valve springs. Call me with your heads numbers and I'll be most happy to help you. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 17, 2001 | 09:00 AM
Brother J's Avatar
[quote]Originally posted by N2O Guy:
<strong>I would go with a cam that favors the exhaust duration 10 degrees @.050 and .010-.015 on the exhaust. 112 is a good lsa for spray. I would have to see your flow numbers at the various lifts to help more but as long as you get somthing in there that has the same amount of lift as your heads peak flow you will be good. also remember that what we are trying to do is fill the cylinder with as much spray as possible so you will want a cam that pops the valve open at just the right time so your air speed is at its peak. Th e trick is to have it aggressive enough but not overly aggressive..The later will eat valve springs. Call me with your heads numbers and I'll be most happy to help you. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> </strong><hr></blockquote>
I've heard that the GM hotcam is a fairly good choice for N2O. What are your thoughts? BTW, I have the F-1 dry kit on order and can't wait to try it out. 1st time N2O user!
Old Nov 25, 2001 | 02:48 PM
Holes02's Avatar
What about a cam something like this:
.563/.563 224/228 with either a 112 or 114 LSA
On an A4. This would go on with Heads as well.
Car most likely see about a 100-150 shot.
Which LSA would work best and what kinda converter would you recommend?
PS - Car will have programming done as well.
<img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 25, 2001 | 08:10 PM
Holes02's Avatar
Anyone wanna help me?
TTT
Old Nov 25, 2001 | 09:30 PM
BYBYC5's Avatar
*Bad Trader*
im pretty sure a 114ls is much better than a 112ls for n20 use
Old Nov 25, 2001 | 09:32 PM
BYBYC5's Avatar
*Bad Trader*
i went 11.7 with just a 150nx wet shot <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 25, 2001 | 10:06 PM
cantdrv65's Avatar
[quote]Originally posted by Grinch:
<strong>im pretty sure a 114ls is much better than a 112ls for n20 use</strong><hr></blockquote>
I'm getting alot of conflicting responses on that subject. Some say the 112, some say 114???
Old Nov 25, 2001 | 11:06 PM
RyanJ's Avatar
SSU Moderator
[quote]Originally posted by Holes02:
<strong>Anyone wanna help me?
TTT</strong><hr></blockquote>
thats a good cam, 114 or 112. if you going to do custom programming (which youll need anyway) get it on a 112. sounds better and its better for N2O. just make sure to get some good springs.
Old Nov 25, 2001 | 11:08 PM
RyanJ's Avatar
SSU Moderator
<strong>oh... a local guy went 11.4's with a t1, macs, and a hidden 100 or 125 shot. (drag radials i think)
i went 11.7 with just a 150nx wet shot <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> </strong><hr></blockquote>
i didnt say that was a bad *** time, just that it is fast (uhhh .3 faster than you <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> ) and i was backing up my T1 for N2O argument. and an auto with a wet 150 is A LOT different than a 6-spd with 125 dry.
Old Nov 25, 2001 | 11:32 PM
BYBYC5's Avatar
*Bad Trader*
ok ok .30 faster, lol no flame intended, just wanted to point it out, i didnt even see the fact it waS AN M6, <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> <img src="images/icons/wink.gif" border="0">
