Hiding a wet shot...
Old Nov 18, 2001 | 02:45 PM
RyanJ's Avatar
SSU Moderator
Default Hiding a wet shot...
People have brought this up in the past so I thought I'd start a discussion. The 2 biggest problems with hiding a wet shot are the nozzle and the fuel supply. Now, if one were to add a fuel block near the tank and add an additional fuel line strictly for the N2O (there is an extra spot in the plastic clips along the frame) with a Aeromotive regulator somewhere under the car, would this work? That way without using the schrader valve, you could shove the solenoids near the brake booster or behind the PCM. With a stock lid, a nozzle under the intake track would be easier to hide, but with an aftermarket lid, would it be inconspicuous enough?
Thoughts?
Ryan
Old Nov 18, 2001 | 05:41 PM
Terry Burger's Avatar
Default Re: Hiding a wet shot...
Hiding N2O is basically common sense. If you can see something, move it. If someone knows what they are looking for they can always find it though.
Old Nov 18, 2001 | 07:00 PM
RyanJ's Avatar
SSU Moderator
ok...so you think running a separate fuel line from a fuel block and regulator to the fuel solenoid is a better idea than just painting the fuel sol. black and sticking it on the end of the rail? I dont know if it will work or not.
Thoughts?
Ryan
Old Nov 18, 2001 | 10:59 PM
BYBYC5's Avatar
*Bad Trader*
dont waste time, a clean and good install has allways looked better, honestly if u run the bottle ur times will show it so...are u really hiding it?!? <img src="images/icons/wink.gif" border="0">
Old Nov 18, 2001 | 11:18 PM
RyanJ's Avatar
SSU Moderator
i know, id just thought itd be fun. that and i like the look of big NOS Cheater solenoids pushed way back under the cowl with nicely run line to the nozzle. Oh well.
Ryan
Old Nov 19, 2001 | 09:09 AM
blackhawk2000's Avatar
I've always thought about hiding the sprayer in the EGR tube.
Old Nov 19, 2001 | 09:41 AM
RyanJ's Avatar
SSU Moderator
[quote]Originally posted by blackhawk2000:
<strong>I've always thought about hiding the sprayer in the EGR tube.</strong><hr></blockquote>
ohh good idea. any thoughts on the fuel side?
Old Nov 19, 2001 | 11:29 AM
How about tapping into the back of the fuel rail? I'm sure it could be modified somehow.
Old Nov 19, 2001 | 11:38 AM
I have my fuel solenoid painted black sitting on the end of the fuel rail, most people don't notice it.
