What is AGOSTINO doing to their heads???
Old Dec 4, 2001 | 11:53 PM
jhelms's Avatar
Default What is AGOSTINO doing to their heads???
...... to make them stay put under lots of boost? <img src="images/icons/smile.gif" border="0">
I have heard ARE is doing something to keep the heads from lifting with ~14-15psi of boost on ls1's, what's the deal?
tia,
[ December 05, 2001: Message edited by: jhelms ]</p>
Old Dec 5, 2001 | 12:28 AM
SIR's Avatar
SIR
Default Re: What is AGOSTINO doing to their heads???
Maybe studs and o-ring the block.
Old Dec 5, 2001 | 12:31 AM
jhelms's Avatar
Is that all? Someone said they were doing something new, because high boost and ls1's have not mixed well in the past...
Old Dec 5, 2001 | 01:06 AM
ChrisB's Avatar
Aluminum head, and aluminum block now... you could weld <img src="images/icons/wink.gif" border="0">
Chris
Old Dec 5, 2001 | 06:49 AM
cantdrv65's Avatar
Somehow I do not believe you're going to get an answer from Nick on that one. <img src="images/icons/wink.gif" border="0">
Old Dec 5, 2001 | 07:37 AM
BIGBOS's Avatar
I heard no matter what you do the heads come flying off around 22psi... <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Old Dec 5, 2001 | 08:18 AM
Z00's Avatar
Z00
They said they wouldn't be telling because they need to recuperate their research costs in it.
Old Dec 5, 2001 | 01:11 PM
Black LS1 T/A's Avatar
Moderator
Some of these experienced racers ARE tricking components to keep these beasts together.
You can't blame them for wanting to keep that a secret. Since they developed the techniques, they are probably not wrong to want to keep that to themselves.
Then you would not need their services. <img src="images/icons/smile.gif" border="0">
Old Dec 5, 2001 | 07:04 PM
jhelms's Avatar
That's cool I can certainly understand them wanting to keep things a secret.
Soooooo how much boost is 'safe' for a 9:1 cr LS1??
Old Dec 5, 2001 | 10:01 PM
1CAMWNDR's Avatar
[quote]Originally posted by jhelms:
<strong>That's cool I can certainly understand them wanting to keep things a secret.
Soooooo how much boost is 'safe' for a 9:1 cr LS1??</strong><hr></blockquote>
Christ John, you already have a bad-*** ride. Now what are you dreaming up?? <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
I can't complain one bit----when I win the lotto, there will be all kinds of stuff happening here! <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Old Dec 5, 2001 | 11:38 PM
Reckless's Avatar
Super Moderator
"Ancient Canadian Secret" <img src="images/icons/tongue.gif" border="0">
Old Dec 5, 2001 | 11:46 PM
jhelms's Avatar
Ok so a few questions stem from this (and i've already emailed them).
1) How much is there dual in tank setup?
2) How much boost can Eagle SIR rods, 9:1 cr Wisecos, and ported heads take?
3) How much boost could an ARE treated motor take? I mean with their special secret? And how much would it cost to have it done?
Old Dec 6, 2001 | 12:41 AM
Terry Burger's Avatar
MMS sells special copper gaskets and ARP studs, ARE probably does something similar.
Old Dec 6, 2001 | 12:46 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
[quote]Originally posted by Terry Burger:
<strong>MMS sells special copper gaskets and ARP studs, ARE probably does something similar.</strong><hr></blockquote>
ARE does this stuff and a quite a bit more.
I am generally familiar with some of the innovations they have made and Nick really has spent a lot of time and money to do this r&d.
Old Dec 8, 2001 | 07:06 AM
The Derek H's Avatar
ARE can machine the heads for a larger head stud to prevent the heads from lifting. They are doing this with my C5R block. The dual tank pump really depends on the specs I also have it. You can get it with an aluminum casing to replace the factory one that the single pump came in and you can get it with complete plug and play harness. For your application I recommend you call Nick directly. He has worked with me so much its ridicoulous and has to be the greatest person on the planet. Even though he is Canadian <img src="images/icons/wink.gif" border="0">
Old Dec 9, 2001 | 05:10 PM
AREGHOSTZEE's Avatar
Derek is right and it is not really a secret. We are doing all the above. We are installing new headstuds in the block(not as easy as some may think) and do the appropriot machineing to the heads as well as the special gaskets and other things that are needed. We will machine a block and head combo for anyone that wants to send there stuff up. We have done some testing as of late and are still learning a bit here and there, we want to be able to give our customers the latest tech. available on the Ls1's.
Remember one of the most important things, tunning!! too much of this and not enough of that and it doesn't matter what studs and gaskets you have.
