Stock pull vs 100 shot 50-130 vids! 3 second gains?
So I took it out back to back right in a row. First one is stock pull and second is on 100 pill. How much faster are you guys seeing it get to 130 on the 100 shot? I counted like 3 seconds????
http://www.youtube.com/watch?v=1tgyd...2&feature=plcphttp://www.youtube.com/watch?v=CGAZe...1&feature=plcp
Ok set the bottom video where I'm on nitrous at 4 seconds just before I go wot and pause it and than play the first video and than press play on the second video just after I stomp it in the first video. You can watch how much faster it is on the nitrous run!
Yea I'm sure I could hit 10.9's or better if I put some slicks on it. My 12.3 is with a 1.8 60ft and I have added a fast 90/92 since than. With a slick spraying out the hole I'm sure I'd hit 10's pretty easy, but I will more than likely never spray it in first gear or put slicks on it. Unless I found someone willing to let me borrow there slicks for 1 pass and go for a 10.9. I just know somewith will break spraying out of the hole with 100 shot and slicks. I'll prob go in march and spray when it hits second and see if I can get a mid 11 out of it.
Thats kinda like how mine is, once you get up to higher rpms that thing just pulls hard. Too bad once you have that power and acceleration atleast for me started realizing my brakes are not up to par to slow back down quick enough. I guess once im done with suspension i gotta invest money in braking.
yep 3 seconds almost exactly measuring from 70... actually sat here with with a stop watch and timed each one 5 times... lol.
70-100 was about 1.5 seconds different. took 3.9 on the nitrous 5.4 on motor. i measured those times because your car seems to hickup at 105-110 on both nitrous and n/a. any idea what thats about?
im so bored i went to some of my videos..
my old heads cam setup on motor 70-100 4.0 on the 100 shot 70-100 3.5
on 9-10 lbs of boost it is 2.9 70-100. on 12.5 pounds it is 2.4 70-100 in 3rd gear. on 14 lbs it was just about 2 seconds.. sorry... lol im bored.
