Fuel System
Old Feb 6, 2012 | 08:26 AM
redriver racing's Avatar
Default Fuel System
About to step up to a 250 shot what fuel system should i go with? Have a 150 shot now everything works fine. Do i get a standalone or do they make a fuel pump to hold a 250 shot with stock fuel lines?
Old Feb 6, 2012 | 08:54 AM
warriorcustoms's Avatar
Does your motor have nitrous pistons to handle that 250 shot As a general rule 150 on a 4in piston a 4.125 will take 200 & as far as fuel system really might wanna ask the pro tech staff at Mitrous Outlet I would say twin intank 255s will get it done But you might need to upgrade the lines
Old Feb 6, 2012 | 10:11 AM
Yea its a nitrous motor. Was built for a big shot
Old Feb 6, 2012 | 06:54 PM
slippi84's Avatar
What do you have now that your "fine"
Old Feb 6, 2012 | 08:16 PM
PONTIAC SLP's Avatar
Plate nitrous system , Fuel pump 255 or 340lbs , injectors , What's your CR ?
Old Feb 7, 2012 | 07:40 AM
little over 11:1,102 plate, fuel pump-255,50lbs injectors
Old Feb 10, 2012 | 05:47 PM
slippi84's Avatar
You have to factor in how much power you making now. If it were me I would either go with a dual sump pump setup like add another 255 and a Y fitting in your sender or go with a stand alone fuel setup with a sump. It's all preference cause I think that both setups will get it done for you
Old Feb 11, 2012 | 09:06 AM
dnkynrbk's Avatar
I would do a dedicated if you plan on spraying more then a 200 to be safe. I.s it a DP or a plate I didnt see in your post
Old Feb 11, 2012 | 10:04 PM
It's a plate. Think im going to move the battery and put one there..
