could i hit tens on a 200 shot with bolt ons and stall?
its possible with a 150 shot we got my buddys car to run 10.88s on a 150 shot he had 3:73 gear, lid,headers, 3500 stall, worn out 275 mt drag radials, 150k miles on the motor, trans was going out. tapping the limiter in third.., ported tb, alot off tuning, stock suspenion..his car runs lower times on motor than you like 12.3's
because I need a nitrous stall, with a big shot like that it'll blow right through the converter.. or atleast, so i was told. I need something with anti balooning plates, and those plates have been associated with nitrous for a while now. They are used to reinforce the stock parts, to keep them from flexing from the higher rpm and power. I've seen cracked converters before.. so better safe than sorry.
I wasn't happy with my old one anyways, always wanted a twin disk circleD..
How much does your car weigh with you in it? Fix your tranny and do a stall. I don't think you will have issues running 10's. I was planning on running high 10's when my car was bolt ons with only a 100 shot. I did the heads and cam before I could find out though. A higher stall speed converter makes a world of difference.
