150 To 200 shot...minimal gain help???
Recently I went from a 150 shot running 11.4 @120 to a 200 shot and can only best a 11.31 @ 121. My 60's are all over the map from 1.57-1.89. I am trying to break the 10's with the 200 but now I sure somethig is not quite right. I am running at staggering 3,700lbs, so I know that isnt helping. On the 150 I was running running at 29* WOT (pulling 6* from 35), and pulling 9* on the 200 shot putting me at 26*. My runs were more consistent with the 150 shot. I added timing up to 28.5, but that slowed me down on the mph. Any suggestions?
LT1 355, 3.23 gears, 3600 stall, all stock suspension, AFR 195 heads w/ cc306
200 Shot with 9* pulled
72N 48F
72N 48F
Yes, lol but i never looked at it until today....its at 12.6 n/a not sure on spray. when at the track i am only focused on getting down the track.
If your car is spinning that much I wouldn't touch the tune. Get your car to work, then see what you got-
Get you some lcas, make sure your ic is right, get an arb, and a good tq arm and that thing consistent in the 60- once your there, then start looking at your tune.
Will do. Thanks for the help.
It's a Nitrous Outlet Plate System with the stock intake. My 8 cylider is fine, it's the 1 hole that seems to get hotter than the rest. But even it looks "ok".
