Anyone seen one of these? Or sprayed with one?
Old Jun 1, 2012 | 12:45 AM
blackonblacksls's Avatar
Default Anyone seen one of these? Or sprayed with one?
Throttle body with built in nitrous ports. Going to use it as my second stage. 100 shot maybe 150. On top of my 250 direct. Anyone see any issues or have any bad experiences? Or know what might be the useable limit?
Old Jun 1, 2012 | 12:49 AM
ANTICOP RAM AIR's Avatar
well, at WOT, that blade is pointing the holes down.... wouldnt think that would be good....
Old Jun 1, 2012 | 12:54 AM
What? The holes aren't in the blade? The holes point at an angle towards the middle of the tb and are behind the blade.
Old Jun 1, 2012 | 12:56 AM
do with the blade at 90degrees, the holes point back into the intake?
Old Jun 1, 2012 | 12:57 AM
Oh hell!! I didnt see the three holes and slit in the bottom... I was looking at the blade shaft... lol that looks pretty damn cool man...
Old Jun 1, 2012 | 12:59 AM
Look here... https://ls1tech.com/forums/texas-mem...trous-kit.html
Seems legit..
Old Jun 1, 2012 | 04:39 AM
LS1MCSS's Avatar
At first, I thought the same thing then realized those are the blade screw holes.
OP, The fuel and nitrous holes eem pretty small. Any idea what the max hp level it will spray.
Old Jun 1, 2012 | 09:51 AM
Neal@NitrousOutlet's Avatar
Arrington makes some throttle bodies like this for the Hemi motors. Those ports look a little small to run large amounts of fuel and nitrous threw but could probably get about 100 -125 out of it.
Awesome product non the less:cool
Old Jun 1, 2012 | 10:10 AM
Nitro Dave's Nitrous Outlet's Avatar
Call LMR and ask them about it. I have not seen one in person nor have I flowed one.
Looks like a nice throttle body though.
Dave
Old Jun 1, 2012 | 10:31 AM
Fbodyjunkie06's Avatar
Interesting for sure.
Old Jun 1, 2012 | 12:24 PM
Dave! This is David Peña y'all didn
Direct port on my ls7 fast that I got in my 5th gen camaro.
You think it's worth it to have it sent to y'all and flowed? Or should I trust it with the current jets I'm using in a nozzle tapped into my throttle body?
Old Jun 1, 2012 | 05:49 PM
Firehawk441's Avatar
Originally Posted by blackonblacksls
Pretty trick concept. I'm curious how well it works out for you.
Old Jun 1, 2012 | 06:34 PM
Sofls1's Avatar
This does look pretty cool, now if they could find a way to hide the feed lines!
Old Jun 1, 2012 | 09:32 PM
Blackonblack do you know if the long skinny slit is for fuel or the 3 pin holes? Trying to figure out which one is which.
Old Jun 1, 2012 | 11:40 PM
No clue. When I buy needed fittings I'll spray through it and check out the pattern. But I'm drunk and in a line to get aboard a ferry with the car now.. And we couldn't care less about what hole sprays what!
Old Jun 2, 2012 | 12:21 AM
Drunk driving, nice.
Only reason I wanted to know went along with Dave's comment, they won't be good for much flow from looking at the size of the holes.
Old Jun 2, 2012 | 07:41 AM
firehawk 385's Avatar
I like it, but I'd have it flowed before using it.
Old Jun 2, 2012 | 09:22 AM
Juicedh22's Avatar
The LMR/BVI 102mm tb with integrated nitrous! I have been trying to track one down to run for quite some time. I talked to LMR last week actually, they no longer produce those, and to my knowledge, not many of them exist...
Can't tell from the pic, but if that is a DBW unit and you want to sell, I will purchase from you.
I
Old Jun 2, 2012 | 11:39 AM
Probably don't want to sell it.. It's exactly what I need/want.
Old Jun 2, 2012 | 02:04 PM
01 WS6 6.0's Avatar
http://houston.craigslist.org/pts/3047072274.html
200 craigslist find
