Lovin' the stock cube nitrous progress.
Old Jul 5, 2012 | 10:28 AM
  #41
Fbodyjunkie06's Avatar
Originally Posted by n2ols1cam
Thanks a lot for your help guys! im going to order a set of strange rear shocks sometime this week.
Fbodyjunkie, what do you think about my converter? do you think its too tight? do you have any launching techniques you would recommend that might help me out?
The only other thing I can tell you do to do is try just matting the gas off idle and setting the nitrous to come on at 3000-3200rpm.
How are you pulling timing? Are you pulling one big chunk of timing for the nitrous you are spraying or are you progressively pulling it out?
Old Jul 5, 2012 | 11:00 AM
  #42
n2ols1cam's Avatar
I am pullling one big chuck out. I have 26 degrees of timing in up until 3000 rpm then i have 16 degrees total all the way to red line.
I need to get a window switch, i do not have one yet.
Old Jul 5, 2012 | 01:54 PM
  #43
WheelsUp84z's Avatar
i think you could pick up a good bit by leaving some more timing in it earlier and then pulling it out as the rpm's get up there. Probably a good few tenths in the tuneup.
Old Jul 5, 2012 | 02:04 PM
  #44
n2ols1cam's Avatar
You think so? what would you recommend? also, i am on 93 octane.
Old Jul 5, 2012 | 10:11 PM
  #45
Here is how my nitrous activation and timing correspond.
I have all 27* of total timing in my motor up till 3600rpm. At 3600 rpm I am pulling 2*. At 4000rpm I am pulling 3*, at 4400rpm 5*, 4800rpm 6*, 5200rpm 7*, 5600rpm 8*, 6000rpm 10* from 6000rpm to redline 10* is pulled.
My converter flashes to at least 5400-5500rpm and the car does not even move off of the starting line until then(5500rpm). It doesn't really start to lock up hard until around 6000rpm and really starts pulling then.
From 3600rpm to 5500rpm there isn't much cylinder pressure being created in my car meaning there is barely any load on the engine. Keeping timing in it will really help it move off the line quickly and under power.
You need to get a data log of the car with the current tune and see where you hit 1-5mph in your data log and note what rpm you see at 1mph to 5mph. This will show and tell you where your converter flashes too and starts to lock up. When you really start seeing the mph rise and it's still in the general area of where the converter flashes(400-500rpm from flash point) that's where it couples or beings to lock up hard and is where you need to have all the timing out by, not just where you're activating the nitrous.
It's all about cylinder pressure and load on the motor.
I gained a GOOD bit by going from pulling one chunk of timing out to doing it this way, but using this method you HAVE to read plugs and you HAVE to datalog it at least once to find out where it flashes and locks up at. If you don't you're just guessing.
Old Jul 6, 2012 | 09:27 AM
  #46
n2ols1cam's Avatar
thanks for the help man. as soon as i can i will data log it. what tuning software are you using?
Old Jul 6, 2012 | 10:02 AM
  #47
HP Tuners.
Old Jul 6, 2012 | 10:21 AM
  #48
n2ols1cam's Avatar
HP Tuners.
one of my buddies has HP Tuners, ill have to buy credits and do some logging.
Old Jul 6, 2012 | 10:28 AM
  #49
2 credits is 50 bucks. Well worth it to be able to tune your car and log it whenever you need to.
Old Jul 6, 2012 | 10:41 AM
  #50
n2ols1cam's Avatar
yes very true, i will talk to my buddy and get it set up for the next time i go to the track.
Old Jul 25, 2012 | 08:23 AM
  #51
StrokerTA's Avatar
Well since we have been too busy partying, getting dents pulled, and helping others with there cars... Maybe we should go to the track Sunday with the baby jets and see what she does.
Old Jul 28, 2012 | 11:13 AM
  #52
Dynospeed's Avatar
You can log your car without buying credits but you will have to buy them to make any changes.
Old Jul 29, 2012 | 09:45 PM
  #53
WhiteLTone's Avatar
went out on the 200jets again today, ran into a few issues, but ran decent overall. we got a few things to try and put together before going out next time.
Attached Thumbnails Lovin' the stock cube nitrous progress.-553419_751478131607_2043020983_n.jpg   Lovin' the stock cube nitrous progress.-20120729_174110.jpg
Old Jul 30, 2012 | 09:37 AM
  #54
I really like your hood, have you thought about cutting it back some where the cowl meets the windshield to get some more air in the engine bay? That's a pretty high pressure area right there and might pick it up some, or if you could use an air pan in conjunction with that.
Old Jul 30, 2012 | 10:47 AM
  #55
WhiteLTone's Avatar
I looked into an airpan and cutting it back at the beginning of the year but decided to hold off til i get the super vic.
Old Jul 31, 2012 | 09:50 PM
  #56
WhiteLTone's Avatar
trashed the block on sunday, broke the starter pad off the block. should be back out in a week or two. got a few changes to make. oh yea we CC'd the heads and w/ the pistons and gaskets i've been running, compression has been 10:1. will report back when running again.
Old Aug 1, 2012 | 08:54 AM
  #57
How did you manage to do that?
Man that's two down in the past week! Brett and now yours.
I'm going to start saying a prayer before each of my runs
Old Aug 1, 2012 | 09:06 AM
  #58
WhiteLTone's Avatar
Junk starter got stuck against flexplate id imagine. Took out bendix and flexplate too. Swappin parts to another block. Changing to 12:1 compression.
Old Aug 1, 2012 | 09:33 AM
  #59
StrokerTA's Avatar
One of the bolt holes had been repaired already once before, I'm guessing it musta tried to kick back when he started it pulling it off the trailer.
Luckily I had a spare block sitting here for him, so we are making a couple changes. His new slugs just showed up from Diamond about 45 seconds ago, thanks Fed Ex for your speedy delivery!
Old Aug 1, 2012 | 04:15 PM
  #60
Nice!
