Lovin' the stock cube nitrous progress.
Old Aug 7, 2012 | 07:05 AM
  #61
WhiteLTone's Avatar
So anybody have any insight on what would cause the nitrous to be delayed about half second when launching off the brake? Using a leash electronics single stage nitrous board with tbrake wot switch functions. When testing in garage and pits the solenoids respind (click) instantly upon releasing the tbrake button, but when launching i get about a .5 sec delay. Ive tried purging more thinking there was air in the line, both fuel and n2o lines are equal length. Ive also tried launchin anywhere from 3000-3400rpm off brake. Thinkin i might try 3800 or 4k and see if that dont fix it. Or maybe adding more initial timing to the 3-4400rpm range. Any input is greatly appreciated.
Old Aug 7, 2012 | 08:05 PM
  #62
Fbodyjunkie06's Avatar
Bad relay or ground is my guess.
Old Aug 13, 2012 | 03:46 PM
  #63
StrokerTA's Avatar
I just wanted to post some teaser pics, and let everyone know that the killer is coming.
Nicks new block is almost through the machines.
The new 12:1 slugs are here and so are the Compstar rods.
We are also making some changes to the combustion chamber. And while its all apart we are going to finally port the intake and match it to the cylinder heads.
The record will fall on the 24th or 25th, just wanted everyone to know.
Old Aug 13, 2012 | 04:56 PM
  #64
WhiteLTone's Avatar
weak sauce. that motor will look sexy in that 93 foxbody.
