15974 NOS Mini Progressive Controller Wiring Help
Old Jun 30, 2012 | 10:47 PM
redriver racing's Avatar
Default 15974 NOS Mini Progressive Controller Wiring Help
Wanna see if anybody else has had this problem. When the controller is hooked up and u depress the wot switch something in the dash is clicking. It does not do this without the controller hooked up. What is causing this? We can not figure this out.
Old Jul 1, 2012 | 10:34 AM
Fbodyjunkie06's Avatar
Sounds like the solenoids are clicking?
Old Jul 1, 2012 | 11:06 AM
krissoto's Avatar
Well there are relays built in the setup, they wld be switching back after u depress it. If the set up is on a ls1 u don't need the wot switch bc u can hook it up to the tps.
Old Jul 1, 2012 | 01:19 PM
Its not the solenoids clicking its back feeding or something. Just dont know where its at but its in the dash. What wire/color on the tps do i use. Will try that and see if that works.
Old Jul 1, 2012 | 06:29 PM
meatheadgn's Avatar
It may the actual NOS box clicking when it gets the proper signal. Put your ear or a stethoscope up to it and see if that is where it is coming from.
Old Jul 2, 2012 | 11:41 AM
Neal@NitrousOutlet's Avatar
Hope we can get you taken care of, You called as i was reading your thread.
Old Jul 2, 2012 | 12:45 PM
Will try it later tonight and will let u know. Thank's
Old Jul 2, 2012 | 08:54 PM
Figured out where the noise was coming from, its back feeding through the widshield wiper motor. Not sure how but it is. U can take the wiper fuse out & it quits. But here is the deal u can move the white/hot wire to a different post & it still does it when the wiper fuse is back in. I run the white wire from the progressive to the battery & same thing. So know matter where u put the white wire on the progressive it makes the chatter noise through wiper motor unless u take the fuse out. I also moved grounds to a different location it still does this. The only thing i have done is add the progressive & thats it. Open to any opinions.
Old Jul 3, 2012 | 09:04 AM
I would like to give chris @ nitrous outlet a big thank's for taking the time to talk to me on the phone. Hopefully we can get this figured out.
