msd window switch reading low rpm
Old Jul 21, 2012 | 10:07 AM
Cam99's Avatar
Default msd window switch reading low rpm
Ok hooking up my window switch. 99 SS. Tach signal hooked to the #10 white wire on red pcm plug. Msd set to cyl 1. RPM reads low. Tach reads 600 at idle msd reads 300. At 1500 rpm msd reads 600. 2000 rpm reads 850 on msd. What am I missing here?
Old Jul 21, 2012 | 10:09 AM
Fbodyjunkie06's Avatar
Have you tried 4 cyl mode instead of 1 cylinder?
Old Jul 21, 2012 | 10:12 AM
firehawk 385's Avatar
Cut the 2 looped wires.
Old Jul 21, 2012 | 11:13 AM
Cam99's Avatar
I only tried it 1 cyl. What looped wires?
Old Jul 21, 2012 | 01:02 PM
Firehawk441's Avatar
If this is the window switch you're using, the blue and red looped wires need to be cut like this.
Old Jul 21, 2012 | 01:41 PM
Cam99's Avatar
oh, i see. mine is the digital window switch so no looped wires
Old Jul 21, 2012 | 03:52 PM
Cam99's Avatar
You are the man. Works like a charm on 4 cyl mode. Thanks!
Old Jul 21, 2012 | 05:50 PM
Aww you made me blush
