TPS wire with LS2 TB on LS1 ...?
Old Jul 25, 2012 | 03:16 AM
RideZX-6R's Avatar
Default TPS wire with LS2 TB on LS1 ...?
Which wire is the my TPS wire on my TB?
I have an LS2 TB on my 99 C5 (LS1) and the Summit Racing adaptor harness...
I tapped the blue wire however after more reading is seems like the purple or green could be it as well.... Which one do I need for TPS to wire to my dynotune controller?
Thanks!
Old Jul 25, 2012 | 04:33 PM
RideZX-6R's Avatar
Any help is appreciated!
Old Jul 30, 2012 | 04:28 PM
RideZX-6R's Avatar
top - anyone
Old Aug 1, 2012 | 08:32 PM
warriorcustoms's Avatar
I used the search & found Dark Blue wire!!!!
Old Aug 1, 2012 | 08:38 PM
LS1MCSS's Avatar
what pcm are you using?
Old Aug 1, 2012 | 08:55 PM
RideZX-6R's Avatar
Stock 99 FRC PCM...
and warrior can you show me the thread you found? I'm asking because I actually tapped the blue one first and it threw "reduced engine power" for me - so I figured it wasn't it
Old Aug 1, 2012 | 09:14 PM
Damn LoL Im not worth a **** at links Lemme see if I can try LoL
Old Aug 1, 2012 | 09:21 PM
htpp://ls1tech.com/forums/nitrous-oxide/703330-tps-wire-c5-wot-switch.html This is one of em I found. Hope it helps
Old Aug 2, 2012 | 05:07 AM
LS1MCSS's Avatar
Originally Posted by RideZX-6R
Stock 99 FRC PCM...
Blue is the signal wire.
Old Aug 6, 2012 | 05:12 PM
Chris@NitroDaves
Guest
Posts: n/a
Being you have the 99PCM and the only thing that is different is an adapter harness you should still be able to tie into the blue wire that is on the factory side of the harness and it should work. If not you might have to end up going off the PCM.
