Our 479 LSx nitrous install
Old Sep 11, 2012 | 06:07 PM
Gforce Engineering's Avatar
Default Our 479 LSx nitrous install
I thought I would show off our Nitrous Outlet Direct port we just installed on our shop car project.
If you remember our combination last time, we were running a 403ci LS2 with a 300 shot and ran a best of 9.41 @ 145 mph. This was 3 years ago..
Now we are running an 479ci LSx block, PRC 285 LS7 heads and a mild hyd roller set up.
The car has our 9" and just about every trick piece of hardware we and our vendors offer.
Here is our new Ryan Beck (Burgers) engine.
Our new nitrous kit from Nitrous Outlet. I'd like to thank Dave and Chris for putting up with our gotta have it next day pestering and excellent customer service!
Follow along as we install and test this nitrous system, there will be some good tech in here.
Thanks
Chris
Old Sep 11, 2012 | 06:08 PM
We installed twin Nitrous Outlet ceramic bottle heaters, these things are sweet!
Today we will be drilling and installing the direct port nozzles.
Ok folks, all done and ready to bolt the intake back on the car for wiring and final plumbing.
Here is a run down of all we did.
First step was locating where the nozzles would go.
Then we had to drill and tap the fitting holes into the Nitrous Outlet fuel rails.
We are fortunate to have a cnc mill that made quick work out of this.
The fuel rails come extra long so you can cut them to a shorter length if you want. We cut ours to 12" long.
That gave us plenty of room to space the fittings out so they were easy to get to and we could also put the solenoids on each end without hitting anything.
I've got a video of doing this on our cnc mill I'll upload later.
Now we start bending and running the tubes
And now it's ready to bolt the intake back on the car to finish up the wiring and supply lines.
We will also now be installing our stand alone fuel system.
Old Sep 11, 2012 | 06:10 PM
We had the car on display at Holley Fest, a Holley Engineer came by and took lots of photo's, he loved it! LOL
Old Sep 11, 2012 | 09:47 PM
ATVracr's Avatar
Nice!
Old Sep 12, 2012 | 11:03 AM
Neal@NitrousOutlet's Avatar
Looks good guys!!!
Old Sep 12, 2012 | 11:10 AM
alans02z's Avatar
Saw it at the lsfest. Looked insane. Pics dont do it justice
Old Sep 12, 2012 | 01:20 PM
Nitro Dave's Nitrous Outlet's Avatar
It was great meeting you guys at LS fest. I loved the car and you guys did a great job installing the system.
I love going out to these races and seeing our products on every ones Hot Rods.
Thank you for all your support!
Dave
Old Sep 13, 2012 | 01:27 PM
ShiznityZ28's Avatar
what did it run?
Old Sep 13, 2012 | 05:48 PM
blacktransam's Avatar
I just went all over your website and so no info on said 9"
Old Sep 15, 2012 | 06:28 PM
Sales@Tick's Avatar
Looks really good, I like that intake!
Old Sep 18, 2012 | 04:18 PM
Dave
Yep, that's why we go as well. Just this time we were the ones needing the help LOL
Thanks man!
Originally Posted by ShiznityZ28
what did it run?
Never did use the nitrous, it wasnt running right and was smoking every pass.
We pulled the heads when we got back and found we had a couple valves contact the pistons on 1 & 2. Pretty sure we did it on the dyno when we got the engine running.
It went a 10.05 @ 133 on the motor in True Street though. We will have it out at the LSx Shootout and will be spraying it.
This is the 9" we have in our shop car
http://www.shop.gforce1320.com/produ...3&categoryId=3
We also make them for the new Camaro's, G8 and CTS-V
Thanks
Chris
