do you guys even HOOK?
Old Jun 12, 2002 | 07:17 PM
bigSS's Avatar
Default do you guys even HOOK?
Ok, i'm going to put on a TNT wet kit (150shot) in the future. That means i'll have 600foot pounds on tap. Will I be able to hook in ANY gear on the street? Since i'm running 4.10s i'm worried I may not even in 4th gear... Should I add 315 Nitto Drags for the street or is it just a futile effort? I don't want to switch to 3.73s!
Old Jun 12, 2002 | 07:33 PM
Ron@Vengeance's Avatar
Default Re: do you guys even HOOK?
I make 533/709 on the TNT 100 shot. With my Nitto 315s, Intrax springs, removed sway bar, and KB DD subs I can hook up prety nice i 2nd gear with warm pavement. Forget first gear though. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 12, 2002 | 09:25 PM
VenomSS's Avatar
Don't dump it out of the hole. And you will be much better off with BFG Drag radials than the Nittos. I've run both, and I always spun the Nittos. The BFG's grab like a mother.....
Old Jun 13, 2002 | 01:07 AM
bigSS's Avatar
BeaSSt - what gears do you have in your car?
Old Jun 13, 2002 | 02:34 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by bigSS:
<strong>BeaSSt - what gears do you have in your car?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have lil boy gears........3:73 <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Dreamin of that 12 bolt with 4:30s <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
BTW, at the track I run 26 inch ET Streets. I leave around 3500 and roll into the juice. Cutting 1.70s on the stock rear(for now)
Old Jun 13, 2002 | 04:31 AM
EVIL's Avatar
i just cut a 1.59 last friday with a 150 shot. but i was on hoosier qtp's and have 3.73's too. i was almost out of gear with 3.73's, so 4.10's you will probably be on the limiter.
Old Jun 13, 2002 | 05:02 PM
BIGBOS's Avatar
I plan on T-braking out of the hole w/a 150 shot... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Hopefully my little 26" Hoosier slicks I am going to get can hold up to that... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 13, 2002 | 08:29 PM
bigSS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BIGBOS:
<strong>I plan on T-braking out of the hole w/a 150 shot... <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Hopefully my little 26" Hoosier slicks I am going to get can hold up to that... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah right! No way in hell i'd say without a full drag suspension. I think your posi is going to break too! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 13, 2002 | 10:50 PM
VenomSS's Avatar
KABOOM........
Old Jun 13, 2002 | 11:00 PM
BIGBOS's Avatar
I got the lovely EATON posi right now...
I won't get that extreme until I put a spool into it.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 13, 2002 | 11:59 PM
383LQ4SS's Avatar
Haha...its a crap shoot. Ive been running a 150-200 shot spraying right out of the hole with a 5000-5500 rpm clutch dump. My stock rear has held nicely. Of course my best 60' is only a 1.58
Old Jun 14, 2002 | 12:06 AM
BIGBOS's Avatar
Your spraying 200 out of the hole w/a 6-speed on a STOCK!!! rear end??
How do you pull that off....
Talk about a Krap Shoot.... <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Old Jun 14, 2002 | 11:08 PM
Ryan K's Avatar
Pathological Modifier
Two weekends ago I cut a 1.48 60' on less than a 100 shot. Of course the Moser did't care one bit!
Ryan K.
Old Jun 16, 2002 | 10:44 PM
Slart's Avatar
Math can solve this question for you. With 4.10's and 600 ft/lbs, in 4th gear you'll 2460 ft/lbs at the axles.
A stock M6 makes 350 ft/lbs, a 2.66 1st gear, and 3.42 rear gears = 3180 ft/lbs at the axles.
So on the juice you're making less torque in 4th than a stocker does in 1st. In reality you make about as much axle torque in 3rd as a stocker does in 1st, so your concerns of spinning the tires in 4th (or 3rd for that matter) are unfounded.
Old Jun 17, 2002 | 12:10 AM
bigSS's Avatar
Slart - Very good point! I did these calculations for my Moser 12bolt, I just didn't think about it this way... thanks!
Old Jun 28, 2002 | 08:28 PM
RAGENZ28's Avatar
I GUESS THE PRICE ON CRACK IS GOING DOWN, BUT ANYWAY I RAN A 1.31 60FT SPRAYING 250 ON THE LINE ON A T-BRAKE, IF YOU HAVE A STREET CAR AND WANT IT TO WORK ALL THE TIME, USE A DRY SYSTEM WIRE IT UP TO RUN AS A 2 STAGE ABOUT 50 OFF THE LINE 75 IN 2ND, IT CONTROLS TIRE SPIN AND IS EASLIER THAN ONE BIG SHOT WHICH WILL 1/2 THE TIME SPIN, USE A BFG DRAG RADIAL OR A HOOSIER QUICK TIME PRO DOT THOSE HOOK HARD STREET OR TRACK
