How could this be done?
Old Jun 15, 2002 | 01:42 AM
KillerD's Avatar
Default How could this be done?
I want to bypass my NOS bottle heater thermostat (doesn't work anyways) and just be able to turn on the heater when I flip the switch to engage it.
Thanks
Mike
Old Jun 15, 2002 | 04:02 AM
383LQ4SS's Avatar
Default Re: How could this be done?
Sure can! I never liked my thermostat. I just ran the switch and relay...just keep an eye on the pressure. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Jun 15, 2002 | 11:58 AM
KillerD's Avatar
sweet! I am not so hot with electronics... would you have any details on how to do this? Thanks!
Mike
Old Jun 15, 2002 | 02:59 PM
Andy West's Avatar
Since the switch that heats the rear hatch glass is designed to only stay on for only so many mintues, depending on outside temperature, I wonder if it would work out running contecting the manual switch for the bottle heater to the rear defrost switch? This way to heat your bottle and keep the rear hatch defrosted, just hit the defrost button. It should then switch off before the bottle and rear glass is overheated. Then in cold weather, you could get in, start the car, then hit the defrost, warming both. Like a 2 for 1 deal.
I am not saying this is a perfect idea. Just wondering. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jun 15, 2002 | 05:23 PM
383LQ4SS's Avatar
Andy...When I first got my kit thats how I had it hooked up. But I had to disconnect the rear defroster element and run the bottle heater only. If I tried both it would trip the breaker. Other than that it works great.
Old Jun 15, 2002 | 07:42 PM
Andy West's Avatar
383LQ4SS,
Thanks, I never thought about the breaker. Of course I just thought of this, never tried it.
If you say it worked well, I wonder if anything could be done to keep it from triping the break with out any adverse effects?
Good Luck Guys <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 15, 2002 | 07:47 PM
383LQ4SS's Avatar
Andy...short of rewiring the defroster circuit theres not much you can do...in addition to trippig the breaker..the wires at the defroster got so hot that it started to melt the surrounding plastic of the hatch. You could wire in a switch up front to switch between defroster and bottle heater so there will only be one being powered at a time.
Old Jun 15, 2002 | 10:54 PM
oxidizr's Avatar
I've actually run two car's bottle warmers with the defogger switch but in both cases I tapped into the defogger line in the hatch light area and only used it to provide signal to the relay for the warmer. In both cars, no problem has arisen. I can imagine that if you tried to pass all the too high a current through the switch that some "melting" would occur but otherwise I can't see 1.5a 12v load causing a problem.
Richard
spell check edit <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
<small>[ June 16, 2002, 07:19 PM: Message edited by: oxidizr ]</small>
Old Jun 15, 2002 | 11:01 PM
383LQ4SS's Avatar
Great idea!
Old Jun 16, 2002 | 12:18 AM
slow's Avatar
actually its very easy, you can unplug the thermostat, and the 2 wires going to the thermostat should plug together if memory serves me right on the connections, that will bypass it.
Ryan.
Old Jun 16, 2002 | 12:57 AM
99taws6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by slow:
<strong>actually its very easy, you can unplug the thermostat, and the 2 wires going to the thermostat should plug together if memory serves me right on the connections, that will bypass it.
Ryan.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is exactly right.. Keep an eye on the pressure!
Old Jun 16, 2002 | 02:20 PM
Andy West's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 383LQ4SS:
<strong>You could wire in a switch up front to switch between defroster and bottle heater so there will only be one being powered at a time.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I almost typed that in my last post, but then I thought... at that point you would have two switches just to turn the damn bottle heater on!
Oh well, it was an idea atleast <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
PS: I need cam selection help! Feel free to email me people! Thanks <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jun 16, 2002 | 04:51 PM
KillerD's Avatar
I got the bottle to heat now for as long as I want. Works great! thanks everyone! Nother question... how long do I need to let it heat for? I let it heat for a while and was keeping a close eye on the pressure and I waited and waited and the bottle pressure did not seem to rise very quickly at all. It rose a little and bottle was pretty hot to the touch, to the point you would not want to touch it for a long time. I was worried and shut it off but my pressure hardly did anything but raise just a few pounds. Do I just need to suck it up and let it keep heating? I have gotten my bottle filled before and picked it up without cooling (so the pressure would be high) and the temp of the bottle did not seem really hot and I had pressure like 920 or so. So I figure it takes longer to heat the bottle from the outside in vs having it heated from within to out. Should I just leave the heater running even though the bottle gets really hot until it reaches the desired pressure?
Old Jun 16, 2002 | 07:23 PM
oxidizr's Avatar
Bottle pressure rise time is directly proportionate to the amount if N2O left in the bottle...the lower the n2o the slower pressure will rise.
A full bottle with a "new style" NOS bottle warmer and good power source will heat a full 10-15 lbs bottle from 900 psi - 1100 psi in about 3-5 mins. A near empty bottle 2-3 lbs left may take 10-15 mins to reach 1100 psi. If your bottle is full of co2 you are never gonna compress the air to reach 1000 psi. Just keep an eye out so you don't melt something down.
Richard
Old Jun 16, 2002 | 11:27 PM
KillerD's Avatar
Thanks for the heads up. That helps me a lot. I would think the bottle is getting rather low in juice left so im sure thats the problem. I just bought the NOS bottle warmer off Jegs just bout 2months ago to should be the "new style" i guess...
Also what do you guys usually pay for NOS refills? I have been paying 3 bucks a pound. Is this too high?
Old Jun 28, 2002 | 08:30 PM
RAGENZ28's Avatar
EVER SEEN A NITROUS BOTTLE EXPLOAD? YOU DON'T WANNA LEAVE IT ALONE YOUR TALKING ABOUT YOUR SAFETY
Old Jun 29, 2002 | 05:35 AM
Mike's 01WS6's Avatar
Nitro Daves sells the pressure transducer for the NX warmer by itself for $114 if you're concerned about the pressure.
