Best N2O kit
Old Jun 19, 2002 | 12:23 AM
blkonblk00ss's Avatar
Default Best N2O kit
What is the best kit to run on my car it is a 2000 camaro with a few bolt-ons. I was wondering which brand , how much of a shot and to go with the wet kit or dry kit ????? Anyhelp is greatly appreciated.( Thanks )
Old Jun 19, 2002 | 01:32 AM
BIGBOS's Avatar
Default Re: Best N2O kit
TNT F1 kit, its a wet kit... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Bottom line, its the best.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 19, 2002 | 06:44 AM
Mike's 01WS6's Avatar
That partially depends on what your trying to do. The NOS5177 kit is good because you dont have to worry about leaking fuel solenoids, getting fuel puddled in the intake and blowing it up, and it is less harsh on your drive train. Dry is limited to 125 hp.
Old Jun 19, 2002 | 08:04 AM
Bottled GTA's Avatar
There are a lot of things to consider...
Wet or Dry?
How much are you going to be spraying?
Budget?
I am a strong supporter of NX kits. They are rated at rwhp, same with TNT kits. NOS kits are rated at the flywheel.
I absolutely do *NOT* reccommend the TNT LT1 kit to anyone. That was the biggest nightmare I've ever encountered. Took over 30 hours to get it installed on a 95 z28, and that was with HEAVY modification to the plate, plenum, waterneck, and all kinds of other stuff in the way.
The F1 Kit for the LS1 may be different, but after the experience I had with TNT, I have no faith in their products.
Old Jun 20, 2002 | 03:20 PM
85transamtpi's Avatar
The Venom kit is IMO the best. Easy to install and gives you complete control.
Its dry...but not really. It pulses your injectors for more fuel.
-Doug
Old Jun 24, 2002 | 07:02 PM
Nitro Dave's Nitrous Outlet's Avatar
Nitrous Express,
Its a wet kit so it will give you more low end torque, which will give you more horse power. The way their Nozzles are designed the nitrous and fuel mix together and come out in a mist. No real need to worry about fuel puddleing. The nozzles are even safe to run with super charged applications. There iceman solenoids have a lifetime warrenty. If they go bad simply send them in.
<small>[ June 24, 2002, 07:37 PM: Message edited by: Nitro Dave's Performance ]</small>
Old Jun 28, 2002 | 08:17 PM
RAGENZ28's Avatar
150 HP OF N20 IS WORTHLESS ON RADIALS AND ANYONE TELLS YOU MORE POWER IS BETTER IS FULL OF IT, GET A DRY NOS SYSTEM USE THE TWO SOLINOIDS MAKE IT A 2 STAGE ABOUT 50 HP OFF LINE AND 75 IN SECOND WORKS GOOD AND WON'T BLOW OFF TIRES, I HAVE A 150 HP WET KIT AND WITH OUT DRAG STYLE TIRES IT'S USELESS
Old Jun 28, 2002 | 09:33 PM
Vengeance Racing's Avatar
LS1TECH Sponsor
Get two kits a NOS dry and a TNT. Use the dry off the line like a 50-75 and in second tap that 100-150 TNT but hold on this a pro set-up. OH and by the way buy some BIG sticky tires!!!!
Old Jun 29, 2002 | 01:45 AM
Thats where the Maximizer comes in.You can adjust your kit to come in from 10% to 100% as you need it.This will keep you from blowing your tires off.You can have the best of both worlds.
Dave
Old Jun 29, 2002 | 05:14 AM
RAGENZ28's Avatar
TIMER AND PROGRESSIVE KILL SOLINOID, THE DRY KIT HAS 2 N20 SOLINOIDS MAKE IT A 2 STAGE 50 OF HOLE 75 MORE 2ND 125 TOTAL IS A EASY LOW 12 CAR ON RADIALS
Old Jun 29, 2002 | 03:15 PM
If you are looking for the best results from nitrous.The wet kit is the way to go.We have a 2001 TransAm with Nittos.We are spraying a 150 shot and having no problem hooking.If a two stage is what you want they have wet two stages also.
This kit is really for people that want real results for the money.If your going to spend the money why not by the best for your money.This kit cost around the same as a dry NOS kit and will blow the doors off of it.
Dave
