Check my plugs from track today.
So, I am speculating that if a certain amount of timing is the fastest, but the strap shows too much heat, then it is time to go colder on the plug. Or, conversely, if the car runs it's fastest at a certain timing and there is no heat showing on the plug, you might go to a colder plug?
this is where you can get in trouble, there is no set place the mark should be, if the heat is on the tip on a #9 plug, throwing a #8 in there might move it to the middle of the strap but if you chase that mark your going to hurt something. You can try running a colder plug and leave everything the same, if you pull a degree and she slows down put that degree back in and then try to go the other way until the car slows, at that point is when the motor is happy. Maybe I misunderstood your question.
It will be a while before I tune more cuz I want to put axles in the car before I push my luck anymore. Also, I have no rollbar, so that makes it tough to rip off several mid 10 second passes in a row for testing.
Most said it could probably take more timing and be a little leaner. I am tempted to just up the nitrous jet from 55 to 57 and leave the timing and see how that looks although I know I will not learn what the car likes for tuning that way.
For additional info, the car was varying between 11.6 - 11.8 on the wideband during the pass.
It depends...........on the combo. While it will work, most any combo only spraying a .028 jet, should not need a -11 plug.
People forget what a sparkplug does. It's ONLY function, is to light the fire, thats it. There is no performance gain or loss, in the basic function of a plug. While you can hurt the performance, with too cold a plug in a N/A combo, that is rarely the case in a nitrous motor. A "hot" or "cold" plug, only refers to the insulation around the electrode and how much heat the electrode retains between firing cycles. The "hotter" the plug, the earlier it lights the charge, because of the heat, retained in the electrode. Using this information, you could deduece, that about ANY heat range plug can be used, as long as you manipulate the timing correctly and you would be correct in that assumption.........but.........a "hot" plug can get you into trouble very quickly, because it retains so much heat between cycles. This gets you into a pre-ignition territory, that can play havoc on your tune up. You are much better off with a cold plug. This allows you to control the start of the burn, more or less with the timing only and not have to take the heat in the plug, into account.
I personally like to run as cold of a plug as the engine will tolerate and keep clean, while idling and doing a burnout.
But the cylinder temp DOES change with the colder plug and same timing, because of two reasons.............One, there is 140* tip temp change in the plug and two, the colder plug, ignites the charge later, hence the temp is less.
The plugs don't lie. Regardless of heat range, if the plug looks hot, it is.......if it looks cold, it is. One place where people get confused, is thinking the cold plug, makes their tune rich. While there is a small change, in the look of the fuel ring, from one heat range to the next, on a PROPER tune, the change is not drastic. Lets say, the entire porcelain was stone white on a -10 plug and you put a -11 in there. You MIGHT, I repeat MIGHT, see a little color on the plug, but it would not be much. The point here, is if you take a -11 out and it is black, and somebody tells you the plug is too cold and a -10 will clean that right up...........ain't gonna happen. Nine times out of ten, a plug with black porcelain is rich and a heat range change on the plug, is not going to fix that
Here are two great posts monte smith posted see if that clarifys it for you.
new to nitrous the plug read post are great stuff, i need more information on reading plug dont really know what im looking at, i know if they are peppered to back it down, what i wanting to learn is fuel ring and ground strap heat ,like to see pic. so i dont have to learn this the hard way . seen one site a guy refered to the other night,was not alot there, if any one has any thing else i would appreciate it greatly
