Problems with 5177..... please help!
<img src="http://solo2.abac.com/avigdor/temp/Z28/Nozzle%20front.JPG" alt=" - " />
I also had an MSD window switch installed along with a throttle position switch and the standard FP switch, the stock MAF has been descreened. The 15LB bottle is mounted in the spare tire well. While testing the car in the shop the system worked perfectly. However once we took the car out to try it on the street the car was surging violently, almost like you where turning the switch on and off (not like a low NOS pressure surge). So we start trouble shooting the following with no improvement at all (the bottle was full @ had plenty of pressure)...
1) bypass FP switch
2) bypass MSD window switch
3) change arming switch
4) change NOS solenoids
5) change stock MAF to an aftermaket MAF
6) change NOS relay
7) change NOS nozzle
8) verify wiring and grounding
9) verify bottle weight and pressure
10) verify NOS lines
After 3 hours of trouble shooting we called it quits. The system was installed by one of the largest speed shops in Toronto, so they know thier sh_t and they where stumped. They are going to call NOS tech support on Monday, I thought I'll bounce this off the forum members here to see if this is a problem that anyone has encountered.
Does any one have any ideas???
The other thing you can do is temp install a test light from the power output of the relay (going to the noid) to ground. That way when you spray you can see if the power is being cut to the noids. If so the problem would be electrical to the kits wiring. If not...it will be either flow related(valve,pickup tube or lack there of, kinked hose, plugged filter screen, etc) or tune problem (plugs, nozzle placemnt, computer problem, fuel pump, etc) It would be nice if you could ATAP to monitor some engine parameters like 02's and MAF flow rate to see whats going on.
Your guys sound fully competent and Im sure you will get to the bottom of it with some more daylight and troubleshooting.
Good luck! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ July 05, 2002, 11:39 PM: Message edited by: 383LQ4SS ]</small>
Details of my car...
-2002 M6 Z28
-LM cat back
-FTRA+LID+K&N
-B&M Ripper
-SS 10 spoke 17"s w/F1's
-20% tint all around
-dyno @1450 miles with bolt-ons 323HP & 340LB/FT
-best ET 13.3 @ 107 & 2.1 60ft
We started with 13600 nozzle and then switched to the 13500 nozzle and there was a very little difference. Both times the nozzle was aimed at the MAF.
<img src="http://solo2.abac.com/avigdor/temp/Z28/4nozzles.gif" alt=" - " />
I doubt I'll find someone with a lid locally (Toronto), so I'll probably try plumbing the nozzle in the conventional location. Worst case scenario, I'll plug the holes if this does not work. I think I'll end up buying another lid in case I have to go in for warranty work.
You are not giving the nitrous enough time to atomize. Try moving the nozzle back. Since you descreened the maf, there is nothing to aid in atomization, not to mention that spaying directly at the maf that close, can easily knock off the filaments in the MAF and cause problems in the future.
Also doing this close can lean the car way out......have you done any A/F testing?
I just got back from a weeklong business trip to Seattle, so that explains my absence from the board. I spoke with the shop that installed my NOS kit and they spoke with the folks at NOS and they said the problem with my setup was that we where freezing the MAF. So I went back to the shot tonight and they spun around the nozzle so that it was facing the front of the car. We took it out for a trial run, and all I can say is...
HOLY FREAKING MOLLY (trying to stay G rated here)
2nd gear spins like crazy to the point that it's scary, 3rd spins like 1st did before the spray and 4th will chirp if you shift hard. Keep in mind this is only with a 100HP shot.
PS. on a side note, while driving home on a deserted freshly paved 4-lane country road I decided to try a 2-3-4 run. I kept my foot in it through 2nd, spun all the way through 3rd and chirped 4th... just then I see a cop car approaching in the oncoming lane. I jump on the brakes and do my best to slow down. I look in my rear view and the cop slams on his brakes and does an 'action movie' style 180. I proceed to pull over and wait for the cop to catch up. I knew I was toast. He comes to the car and says he had me doing 147 in a 60 zone on the oncoming radar. I just said 'holy smokes'... he was young guy about my age (~30) with a crew cut and a goatee... as he was saying this he laughed and said this would not help out my insurance premium. He asked if I was trying out the car, and told him that I guess I chose the wrong spot to open her up. He saw that I still had my temp plate stuck to the windshield and knew that the car was relatively new. He proceeded back to his car with my license in hand, I looked back out the window and asked if I would still have a driver’s license when he got back, he laughed... I was serious. When he gets back to my car, he tells me before giving me my ticket that I better pay this right away and that if he sees me taking this to court that he’ll be knocking on my door. He gave me $42 ticket with no points for doing 15 over, I told him... "G-d bless you".
<small>[ July 17, 2002, 03:59 AM: Message edited by: vmax1500 ]</small>
Thats great...glad you got everything worked out.
I think i am going to talk to you when i get my kit. I like your approach on the placement of the nozzle in relation to you COMPLETELY stealth/sleeper approach. That what i want, without the problems,
The shop that did the work was great, the did not charge me for the extra time it took to solve the problem!
The only problem is that I went through my 1st 15lb bottle in the 1st 24 hours <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
<small>[ July 18, 2002, 08:19 AM: Message edited by: vmax1500 ]</small>
