Anybody use this on a Direct Port?
Old Dec 31, 2012 | 08:05 AM
jesse92's Avatar
Default Anybody use this on a Direct Port?
Just curious if anybody has used something like this on a Single dry DP setup. I am not looking for an all out build but just a simple clean setup? Intake is a FAST 102 btw.
http://www.summitracing.com/parts/nex-91017/overview/
http://www.summitracing.com/parts/no...0nos/overview/
Old Dec 31, 2012 | 02:43 PM
Chris@NitroDaves
Guest
Posts: n/a
The NX Part couldn't be used at all. Thats a Nozzle Fitting. The NOS Version could be used in theory because it's a nozzle that accepts a jet not a fitting. I've never personally seen anyone use them on a DP application.
Old Dec 31, 2012 | 06:03 PM
red fury's Avatar
chris could you post up some picks of what yall use for dry dp and some intakes yall have done with dry dp
Old Dec 31, 2012 | 06:43 PM
soundengineer's Avatar
dude... Just go to the Nitrous outlet website...
theres about 800 pictures on there or all sorts of intakes... plates and Direct port
I'll be nice and post a picture of mine....
Old Dec 31, 2012 | 06:51 PM
a few more pics of just the intake
Old Dec 31, 2012 | 07:24 PM
fatboyzcamaro's Avatar
Soundengineer
How u like that TB. Any issue with it
Pro n cons.
I have one I'll b using in the next couple months.
Old Dec 31, 2012 | 07:28 PM
no issues for me...I like it
though, I'm considering changing from a GM IAC to the Ford IAC because it reacts faster.
if you get the Scorpion TB, you just need to add a TB spacer with some custom shaping, or you need to grind on the intake a little
the butterfly's are bigger than the 4150 opening, and you need to come up with a way to make them clear so they can open all the way...
my solutions was a single hole spacer with a custom slope to match up with the Scorpion TB butterflys
Old Dec 31, 2012 | 07:57 PM
Gordon0652's Avatar
Why do you have 4 solenoids?
Old Dec 31, 2012 | 08:00 PM
Dual Stage Dry Shot, Dual Purge
one Solenoid per stage
one purge per stage
this is setup right now as a 350 shot
1st stage is a 150
2nd stage is an additional 200
Old Dec 31, 2012 | 08:02 PM
Gordon0652's Avatar
one purge per stage
1st stage is a 150
Thank you, I was trying to follow the plumbing but was thinking - two purges? Figured I was seeing things.
Happy New Year Sir.
Old Jan 1, 2013 | 01:53 PM
red fury's Avatar
Thanks for the pics! Very clean.
Old Jan 1, 2013 | 09:28 PM
jesse92's Avatar
Not saying it is ideal but if a jet can go in one side and you tap threads for the other side why could it not be used. I have seen where a X275 BBC efi setup used just a fitting not sure exactly which brand running 4.80's on a single so it flowed some juice.
