Cant Find HSW MicroEdge User Manual
I am trying to setup my MicroEdge and i cannot find the user manual anywhere. Does anybody know where i can find one? Or does anybody have one in PDF they could email me?
I ended up finding a pdf of some type on the MicroEdge. its not the same one that you posted. between the two, people should be able to figure it out. I finally figured mine out after banging my head against the wall for several hours yesterday.
carmanbabin.com/MicroEdge_Install.pdf
I have the original PDF from their website when it was available, if you still need it, shoot me a pm with your email and ill send it
Step 1: Try to contact HSW, Get Nothing... no help, no support
Step 2: Try Again to contact HSW, Get Nothing... no help, no support
Step 3: Try AGAIN to contact HSW, Get Nothing... no help, no support!
Step 4: TRY AGAIN to contact HSW, Get Nothing... no help, no support!!
Step 5: Throw HSW Microedge in the TRASH!
Step 6: Buy a Better Controller from a company that actually cares about their customers and will actually will provide support if you need it.
oh, and dont forget... if you keep the HSW Micro Junk
dont Just expect it to give you x amount of timing retard....its totally dependent on your tune....you have to have timing removed in the IAT tables for it to actually remove timing as it tells the pcm that you have Hot IAT's to remove timing
