Timing twister installed and not pulling time! HELP!!!!
Old Jan 2, 2013 | 06:06 PM
bernarlitt's Avatar
Default Timing twister installed and not pulling time! HELP!!!!
I installed my msd timing twister and everything seems to be installed correctly but when my tuner hooks up hp tuner its not showing that timing is being pulled.
Does it suppose to show on hp tuner?
Am I setting it wrong? I have the mode on 0 and the 1 degree setting on 7
Does it need a constant power source? I have it on a acc
Old Jan 2, 2013 | 09:37 PM
James@ShorTuning's Avatar
It will not show in timing pull in the log.
Old Jan 2, 2013 | 10:38 PM
BarneyMobile's Avatar
The reason why I don't like the Timing Twister. You really don't know if its actually working.
Old Jan 2, 2013 | 11:26 PM
bernarlitt's Avatar
****!! So is there any way to test it?
Old Jan 2, 2013 | 11:31 PM
bernarlitt's Avatar
It blinks on and off until the rpms gets to 1800 ,then it stays on constant
Old Jan 5, 2013 | 11:21 AM
TA6spdRDC's Avatar
It wont show on HP tuners.. set it to pull max timing and put a light on it. motor will "sound" like its bogging when you give it throttle.
Old Jan 10, 2013 | 05:50 PM
The only way to test it is to mark your balancer and check it with a timing light.
Old Jan 13, 2013 | 12:54 AM
bernarlitt's Avatar
So set it to pull all 28 degrees and give it some gas?
Old Jan 13, 2013 | 06:28 AM
87silverbullet's Avatar
Yes but make sure your nitrous system is disconnected.
Old Jan 19, 2013 | 10:07 PM
bernarlitt's Avatar
When I said "give it some gas" I meant press the gas petal to get it up in rpms. Its suppose to act like it dying out right? And The weather has been terrible thats why I havent went out to the car a tried it. The sleet(snow), rain, and cold as hell has been the my problem
