Anyone running Nitruos without ATAP??
Old Aug 3, 2002 | 12:15 AM
TravWS6's Avatar
Default Anyone running Nitruos without ATAP??
IS it safe and how long have u bin going without it for? o ya and how many shots?? i don't have access to ATAP but do to nitruos!!
Old Aug 3, 2002 | 12:34 AM
Damian's Avatar
LSX Mechanic
Default Re: Anyone running Nitruos without ATAP??
I don't have ATAP and I am running a TNT kit. There are several guy's all over the country with LS1's that know absolutely nothing about the internet and a-tap, but do you think that stops them from running nitrous? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I would say that probably 50-60% of LS1's out there with kits on them don't run a-tap...
josh
Old Aug 3, 2002 | 02:29 AM
TravWS6's Avatar
Ya i was thinkin it wouldn't be so bad to not use it.. as long as i do the bascis eh.. plugs and octain booster?.. then its all good right..?
Old Aug 3, 2002 | 05:17 AM
JoSeY's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TravWS6:
<strong>Ya i was thinkin it wouldn't be so bad to not use it.. as long as i do the bascis eh.. plugs and octain booster?.. then its all good right..?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Man, PLEASE do yourself and a could be motor saving duty, by not skimping on "Protection" type equipment...such as, Simple Autometer Air/Fuel gauge 60 bones w/Gauge pod, clips into the O2 wire on the computer, a FP safety switch incase the Pump goes south suddenly and FP drops....and the MSD Rpm switch...probably add a couple extra hundred easy to the set-up...but I truly believe you'll thank urself in the long run......and Heck, these would go on EVEN W/AN ATAP IMHO.
Old Aug 5, 2002 | 06:11 PM
TravWS6's Avatar
this has nothing to do with the topic.. but what does IMHO mean?? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Aug 7, 2002 | 05:14 AM
99Formula's Avatar
IMHO = In my Honest Opinion
As for N2O without autotap, I'm one of those people. I've never used autotap but have been running a 75-100 dry shot for about a year and a half now. Not sure how many bottles total... Maybe 30 or so 15lb bottles.
Peter
Old Aug 7, 2002 | 08:04 AM
boomcase's Avatar
No auto tap for me i run fine.
Old Aug 7, 2002 | 08:27 AM
myss2638's Avatar
NO autotap here either. As ong as you aren't running some kind of crazy shot you can get by without it(but you won't be able to fine tune your setup either, you need more than autotap for this anywaysie wb 02). Just read your plugs and make sure you aren't running lean.
Old Aug 8, 2002 | 07:58 PM
B18B1LS1's Avatar
My bone stock 98 SS ran O2's around .74-.78 (lean) with the NOS 5177 jetted for a 100 shot. I was also getting 3.9 degrees of KR. I highly recommend Autotap, no two cars are the same.
Good luck.
Old Aug 8, 2002 | 10:42 PM
TravWS6's Avatar
Ok sure... if i get ATAP.. and find out its running lean...?? then what??? don't use nitruos?? go and waste more money on MAFT or other computer programs..? ATAP only shows problems but can't fix them.. em i correct? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 8, 2002 | 11:41 PM
JohnnyZ28's Avatar
Well, I dont have access to a laptop, and buying one plus autotap and the harness would mean over $1K. I dont see that on my agenda list anytime soon.
Old Aug 10, 2002 | 11:53 AM
B18B1LS1's Avatar
You are correct, it only shows the problem. I paid $160 for a MAFT and fixed the problem. I would rather pay a couple hundred bucks over a new motor though.
Old Aug 26, 2002 | 05:43 AM
neat's Avatar
I went without ATAP for about a year. I was spraying a dry 100 shot on a 99 LS1 with a ported mass air meter. After every N20 pass I pulled at least one plug and checked things out. I now have ATAP, and I was running dangerously lean. I have since bought a MAFT and corrected the problem.
I really don't see how a MAFT is wasting money. I bought a laptop for $50 from a pawn shop, ATAP for $150 off this board, and the MAFT for $100. Thats $300 for the whole shootin' match. A far cry from 1k. Look around a bit man, you'll find a good deal on the tuning gear, and be a TON safer.
My .02 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 27, 2002 | 12:22 AM
770Guy's Avatar
I ran a 150shot on my stock camaro without anything, no autotap, nothing and it worked just fine, no detonation
Old Sep 8, 2002 | 03:05 PM
aiwidme1's Avatar
What is ATAP?
