Running Wet System as a Dry one?
Old Aug 14, 2002 | 11:35 PM
Ed Blown Vert's Avatar
Default Running Wet System as a Dry one?
Can you do that on a NX system? Not use the fuel solenoid?
<small>[ August 14, 2002, 11:36 PM: Message edited by: Ed LS1 Vert ]</small>
Old Aug 15, 2002 | 07:46 AM
383LQ4SS's Avatar
Default Re: Running Wet System as a Dry one?
Yep...sure can. Just spray before the MAF and your all set. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 17, 2002 | 01:39 PM
1slowCamaro's Avatar
When I got my charger thats exactly what I did. I just disconnected the fuel solenoid. Works just fine. Just make sure you have enough injector to handle the shot you use.
Justin
Old Aug 17, 2002 | 03:56 PM
Sweet thanks!. Looks like I will getting a NX kit. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 18, 2002 | 01:32 AM
BensZ28's Avatar
Can you use the NX MAF kit with no fuel? Im paranoid about puddling n stuff....
Old Aug 18, 2002 | 07:33 AM
383LQ4SS's Avatar
Ben..No, you cant. The nozzles are after the maf. Its specifically designed to be wet kit.
Old Aug 23, 2002 | 01:02 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1slowCamaro:
<strong>When I got my charger thats exactly what I did. I just disconnected the fuel solenoid. Works just fine. Just make sure you have enough injector to handle the shot you use.
Justin</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What is the correct dry jet sizes? Is it the same wet or dry?
Where can you get them?
<small>[ August 23, 2002, 02:44 PM: Message edited by: Ed LS1 Vert ]</small>
Old Aug 24, 2002 | 06:28 PM
It is the same wet or dry. Just as long as your fuel pump and injectors can keep up. The computer will compensate for the fuel you need.
Old Aug 31, 2002 | 11:20 PM
Thanks the Dry shot is working great!
