Strange Lean condition with plate kit
How long is the car really taking to get above 4500rpms? It can't be anytime at all. I would adjust jetting for the final afr and not the afr you are hitting under light or no load at the beginning of the pull. That wideband isn't telling you crap straight from the hit until all flows have gotten going through the engine.
Heres something else, turn the bottle off, arm kit and make a pull. If it takes a second and a half as you say for the fuel to make the motor cough rich. You have a physical flow issue.
The fuel pump is a brand new Racetronix that we installed the same time as the nitrous kit. Power is supplied via their "hotwire" kit. Regardless, the fuel pressure has been tested at the rail between the rail and the solenoid during a full pull on the dyno. The pressure was verified to hold steady with nothing more than a brief "flicker" of the gauge.
The plugs haven't been verified to be lean. They look fine. BR7EF plugs. The thing is, its stupid lean at first and by the time the run is over it is too rich.
We have the dynojets wideband in one exhaust pipe in a rear o2's location and an NGK AFX wideband in the other rear o2's location and the car has a full exhaust system all the way out the back. No cats. The narrow band sensors do verify the lean condition as well. The way I see it there is nothing left to do but doctor up the NA tune as much as possible in the lean area and let it ride....
If the narrowbands are showing the momentary lean state then I tend the believe it. Also it would likely show on the plugs if you killed the car right when it went lean, but you said it goes rich at the end of the pull masking the lean condition.
Personally I would not let the car go back to the customer if they plan to spray at all, otherwise have them sign a waiver lol.
Being lean can't hurt a nitrous motor, timing does.
But thats a whole nother argument
On a 150 shot there should be no doctoring of anything in order to make it work. I have pulled 300 off the rail on numerous cars without having to cheat anything. There is something being over looked, plan and simple. Do you have anyone who can look at the car? Sometimes working on a problem over and over you may just need a fresh set of eyes on it. I know it can get really frustrating sometimes finding an odd problem.
The AFR naturally aspirated is right on the money and it comes in right away....All the other nitrous cars I've seen/tuned the afr doesn't do this. Yes, they usually have a very brief lean spike then the fuel goes right where it should. That isn't the case with this car.
I have used the fuel pressure gauge I used to test this on multiple cars with fuel volume/pressure issues. A weak pump usually shows up right away in the injector pulse width. More fuel would be demanded at 6500 rpms than at 3500, however we're more than rich enough at that point. I have threw a .033 jet in with a .052 nitrous (100 nitrous, 150 fuel) in it and it will go mid to high 10:1 range at the top. I don't see volume as the issue, it just seems like the fuel solenoid doesn't open as fast as the nitrous one. Even properly jetted on the 100 shot the problem is identical.
I wish that a fresh set of eyes could fix this! We have 4 techs at the shop and nobody has been able to fix this. I have changed everything including the wiring so I'm not sure what anyone else would be able to see.
I'll hit it tomorrow with the bottle off just to see how long it takes for the fuel to bog the engine....but even if it did have a bit of a delay I'm not sure what I would do to fix it. The solenoid has been changed. I can pull an alt off of another vette and try that as well but the voltage on the log is fine. A voltage issue should affect the nitrous side I would think since that noid has about 3 times the current draw in comparison to the fuel. either way it is something else to try.
I have already thought about having the customer sign a waiver stating that the nitrous tune is not safe and to use it at their own risk. However, I'm sure we can command the afr in the tune between 3500-4500 rpms to be a point richer or so with very little change to the numbers it makes on motor anyway. Not something I want to do, but if it comes to it that may be what we have to do.
Of course I'd have to change the tune for the injectors and sell the customer injectors.... And I'm not sure how low I'd have to command the afr to actually achieve what I'm shooting for.
Just thinking outside the box since nothing normal seems to fix this.... Atleast there wouldn't be fuel flowing through an intake that was never designed for fuel to flow through it.
One would thing that a richer fuel jet would richen it everywhere, but it doesn't richen the lean area one bit....just richens it up after 4500 rpms or so. I've even sprayed it by flipping the switch at 5000 rpms and it still had the same amount of time lean, it just wasn't quite as lean.
I'm not sure I follow you on making the PE come on quicker. I have the PE delay set to zero and the enrichment ramp in set to 1.5. PE commanded afr comes in immediately as soon as the car meets all of the requirements and its in as soon as the car is wot. And the fuel is where it should be on motor from 2000 rpms on up till 3500 when the nitrous hits... PE has been active and steady for over 1000 rpms before the nitous even sprays.
I know it's totally different when you are a business tuning someone elses car so my suggestions are just thinking outloud.
I wonder if any of these might be useful:
1. Delay box for nitrous solenoid, allowing fuel to come on first. I know the MSD goes down to 1/10 second for activation.
2. Use a two stage nitrous controller, like the NOS Mini. On one channel bring the fuel in at an earlier RPM?
