Recommended amount of spray?
Engine/Drivetrain Modifications: LS1 from an '02 Corvette; MS3 Cam, factry(shitty)806 heads(that i need to get rid of i know), PRC .650 dual valve springs, titanium retainers, seals and seats, TSP hardened chromoly pushrods, SLP double roller timing chain, SLP ported oil pump, Comp lifters kit, BBK Performance 85mm throttle body, Taylor Cable TB spacer, SLP Flowpac intake package(whisper lid, smooth bellow, forced induction, K&N filter), headman headdress, 3" pacesetter performance off-road Y pipe, 3" cut-out, SLP Loudmouth ll exhaust, 3:73 gears, Jet performance mass airflow sensor, Functional Fiberglas SS Hood. FULLY REBUILT 4L60E, TCI Flexplate, Yank PT4000 torque converter
Suspension Modifications: Hotchkis double adjustable panhard bar, Hotchkis trailing arms with relocating brackets, SLP lowering springs, and Polyurethane bushings
Wheels/Tires Modifications: Front: 17X9.5s & 17X11s w/315/35R17 NT555R Extreem Drag Radials
Also... Should I go with a WOT Switch or push button???
I ran a 150 shot on my stock LS1 for 2 years with no problems.
OP, I run a Nitrous Outlet wet plate kit and love it. I've heard positive reviews for NX as well
OP, I run a Nitrous Outlet wet plate kit and love it. I've heard positive reviews for NX as well[/QUOTE]
Sweet. Can u post a link for the one you're running and where u bought it from?
Yes I would get a little smaller stall like a 3600 from yank. You can leave those heads on there for right now they are not a bad head.
Get rid of that shitty pacesetter y-pipe. Guys have cut the merge out of them and put a flowmaster y in it and pick up 10 hp and 15 ft lbs of torque.
Teenage phenom on here has pretty much the same setup you have and he has gone 9.80's on a 200 shot.
Trey
