Lingenfelter RPM-002 window switch blowout deal!
We are offering our RPM-002 window switch at a huge discount for a limited time only. These boxes go for $109.95, but we are selling them for $79.95. We only have 6 in stock at this price so do not hesitate! Here is a link to them on our site:
http://www.lingenfelter.com/mm5/merc...=#.UWgSYL7D_5o
Please call or email me to get the special price.
Thank you,
Ryan
Thank you,
Ryan
LS1Tech Sponsor
RPM signal
The RPM-002 can take the RPM signal from the coil pack connections on any of the GM Gen III or IV V8 engines (LS1, LS6, LS2, LS3, LS7, LS9, LSA, L92, LY6, etc.). The RPM-002 can also take the tachometer signal wire from the ECM/PCM in any of these applications. If the tachometer signal wire is not already present in the OEM application you would have to add the correct pin to the ECM connector, wire in a pull-up resistor and in some cases enable the tachometer output in the calibration.
Hope this helps.
LS1Tech Sponsor
LSA or LS9
https://www.lingenfelter.com/sites/l...ons%20v2.3.pdf
i guess it actually doesn't work for ls9 or lsa then...
Yes, it does. The RPM-002 instructions just don't include the pinouts etc for the LSA and LS9 applications. That is why Ryan posted that updated pinouts PDF that includes the LSA and LS9. See his earlier post with the attached pinouts PDF.
