Heads/Cam Auto and nitrous?
Old Sep 28, 2002 | 06:02 PM
Zangel's Avatar
Fiery Features Director
Default Heads/Cam Auto and nitrous?
I am considering hooking up the NX wet kit before getting my tranny rebuilt. Is anyone on the stock 4L60 with heads and cam spraying? If so, what kind of tranny problems do you run into? How long have you been spraying the car and how is the tranny holding up? Any info you can give me is appreciated!
Old Sep 28, 2002 | 06:10 PM
Postal's Avatar
Default Re: Heads/Cam Auto and nitrous?
Your more than likely going to hurt the tranny the 1st time out. Spraying through the shifts is going to cause a premature failure.
Old Sep 28, 2002 | 06:39 PM
Zangel's Avatar
I figured that much. I am already having problems with the 2-3 shift. I guess I will just have to wait a little longer to put the kit on the car. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Sep 30, 2002 | 11:52 AM
nysbadmk8's Avatar
6500 405rwhp h&c miles, 5 bottles, nitrous cutoff is 6300 rpm.. Stock tranny
Old Oct 2, 2002 | 06:46 PM
SSprayn's Avatar
heads/cam/150 shot stock tranny. Now have to replace the shift soleniods but they are inexpensive. The car has 56K miles on it.
Old Oct 3, 2002 | 05:43 PM
DanZ28's Avatar
Well, just gonna add this cause it happened to a guy in our club. His stock tranny clutches slipped causing him to hit the rev limiter which in turn caused the intake manifold to hit the hood causing the hood to buckle and an enormous amount of damage. Anyway, the moral is better safe than sorry...Maybe just go with a small shot!
Dan
Old Oct 3, 2002 | 06:02 PM
Zangel's Avatar
I decided to research this a bit more before putting the kit on the car. I talked to a guy that rebuilds trannys for a living and he told me that my tranny wouldn't shift while spraying. I am already having problems with the 2-3 shift on motor. I think I am going to keep looking around for a built tranny before I put the gas on the car.
The guys that are running the nitrous and stock tranny with no problems... how do you have it set up? Is the nitrous on a button or WOT switch? Do you let off between shifts or do you spray right through?
Also, if you will... can you tell me which cam are you running (specs) and what your times are on the gas? Also, what size shot are you spraying to make those times?
<small>[ October 03, 2002, 06:05 PM: Message edited by: Zangel ]</small>
Old Oct 3, 2002 | 08:18 PM
Orange Krush's Avatar
No H/C here bolt-ons only ! <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Window switch is a must to save tranny (3000 to 6000 rpm) ! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Also for street use or track use with DR's I would suggest F.R.E.D. ! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
