My NitrousXpress install so far
Old Apr 15, 2013 | 07:17 PM
stroked383HSR's Avatar
Default My NitrousXpress install so far
Im all mocked up and I just need to drill for the nozzle and then wire all this up and liquid teflon all the connections.
Im going to use my MSD 8969 window switch and i got a ZEX TPS activation switch coming in the mail.
Now im going to have to buy the stupid timing puller...Im gonna get the Lingenfelter LNC-2000 that everyone speaks of.
I just hope I can figure out how to wire all this to run together...LOL!
am I forgetting anything?
anyone know how far in the nozzle really needs to go inside the bellow. Ive got a thread showing how little it does go when using the install nut that came with the kit that i never used anyways.
Old Apr 16, 2013 | 08:56 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Looking Good! The nozzle does not have to go in very far because the stream doesn't come out at a perfect 90 degree angle.
Trey
Old Apr 16, 2013 | 09:50 AM
Blak GT's Avatar
I think you've made up my mind as to how I'm running the purge on my car lol install looks good man! The wiring is much easier than it seems.
Old Apr 16, 2013 | 10:00 AM
yeah its was pretty short piece of 1/4" brake line. 18" i think
and it bends pretty easy. just drilled a hole, pushed it thru and compressed on the purge valve. then bent it to straighten it up.
Old Apr 16, 2013 | 10:10 AM
Rise of the Phoenix's Avatar
Looks good man. That SNS Torque Max Stage 2 is going to love the spray. Spray is next my mod list.
Old Apr 16, 2013 | 10:13 AM
HCI2000SS's Avatar
Looking good man! I'm running the MSD 8959 window switch and LNC-2000 as well. Are you using the LNC to pull timing only? I also have a NX kit as well and the nozzle is just barely into the bellow, but is very secure
Old Apr 16, 2013 | 11:02 AM
thanks...post up some pictures of your install......I wanna see how guys mounted thier window switches and other boxes.
I havent ordered the LNC-2000 yet. Any place I can get it cheaper than what i seen? I'll go ahead and order it now.
only? what else can it be used for? Im just trying to do a simple install.
Old Apr 16, 2013 | 11:11 AM
HCI2000SS's Avatar
I couldn't find it any cheaper, so I went ahead and ordered it from Lingenfelter. As far as the kit that I have it came fully installed when I purchased the car. The window switch that I have is mounted in the glove box, and to honest I can't really tell how it was all wired up. I think it's running to the WOT switch though.
Here is the link to the LNC-2000, and all it's functions. You really only need to use to retard the timing, unless you want a progressive delay, or want to use it as a window switch. I'm simply using mine to pull 4-5 degrees for a 100 shot and that's it
http://www.lingenfelter.com/mm5/merc...e=L460145297&C
Old Apr 16, 2013 | 11:12 AM
2birdJosh's Avatar
Looks good! FUEL PUMP ?????
Old Apr 16, 2013 | 01:26 PM
yeah, ive got a Racetronix with the hot wire kit to install.
Old Apr 16, 2013 | 01:38 PM
Nitro Dave's Nitrous Outlet's Avatar
Looking good. One thing you could do to clean up the install under the hood a little would be to move the nitrous filter back to the bottle area. If you have not already done so you may want to take the filter apart and give it a good clean out before using it.
Dave
Old Apr 16, 2013 | 01:47 PM
Blackpanther99's Avatar
Looks good man.
Old Apr 16, 2013 | 08:24 PM
well today I tapped the bellow and threaded the nozzle in then i started wring it up.
my tps activation switch wont be here til friday and I also ordered the LNC-2000 and it will be here Friday also.
This wiring crap sucks....LOL! so hopefully it will work when im done.
I really dont wanna go any further til I get the other boxes so I can see where to mount those. Im sure close to the window switch.
I'll wire up the switch plate in the ashtray tomorrow.
Old Apr 16, 2013 | 08:29 PM
HCI2000SS's Avatar
Looking forward to seeing how this all works out for you
Old Apr 16, 2013 | 11:01 PM
HCI2000SS's Avatar
Cool! Yours is set up a lot different than mine, but it looks pretty damn nice man! Where you have the MSD box is where I put my LNC-2000
Old Apr 17, 2013 | 09:38 PM
get a load of this gaggle of wires!...LOL!!!
atleast thats done...hopefully its done right..I started getting confused but it should be fine.
just waiting on the LNC-2000 and the ZEX TPS activation switch.
Old Apr 18, 2013 | 08:15 AM
HCI2000SS's Avatar
Are you going to use the LNC unit to just pull timing, or are you using other features too?
Old Apr 18, 2013 | 08:28 AM
just to pull timing....I think thats really all i need
Old Apr 18, 2013 | 08:32 AM
HCI2000SS's Avatar
Yeah that's all I used it for as well. I just tucked away all the other wires and whatnot. Looks good so far man
Old Apr 18, 2013 | 01:54 PM
Looking good If you have any more questions feel free to give me a call.
Trey
