threw a code went i sprayed it, HELP
Old Oct 19, 2002 | 01:02 AM
johnster's Avatar
Default threw a code went i sprayed it, HELP
I sprayed my car tonight, soon as i hit it the ses light came on.The code was po103 it has something to do with the mass air flow.What is this code? why did it throw it? It is a dry kit.
Old Oct 19, 2002 | 10:35 AM
NoGo's Avatar
Default Re: threw a code went i sprayed it, HELP
The code is MAF High Frequency... or basically your MAF is "seeing" such a high reading that the PCM is calling bullshit.
If you saw it from a dry kit, I am going to guess that you either froze one of your resistors (one of your resistors turned into an ice chunk) or your MAF is slightly damaged.
This code is usually thrown when the MAF is disconnected or not connected properly.
Old Oct 19, 2002 | 04:37 PM
PewterZ's Avatar
Johnster...Where is the nozzle installed in your LID? Is it right before the MAF? If it is the MAF is going to freeze like that everytime. Is it a dual nozzle system?
Old Oct 19, 2002 | 04:48 PM
johnster's Avatar
It is a single, I have sprayed it many times and it was doing find.It just did it this one time.I have not sprayed it again.What do yea think?
Old Oct 20, 2002 | 03:30 PM
johnster's Avatar
WELL?
Old Oct 20, 2002 | 04:14 PM
PewterZ's Avatar
Hummm.... What kind of bottle pressure did you have when this happened? Was it kinda low? Where is the nozzle physically installed in the lid? Do you have pics? I would want it as far away from the MAF as possible. I bet the MAF just went bad because of the amount of nitrous that has hit it over time. IMOP I would replace the MAF and move the nozzle to one of the sides of the lid away from the MAF.. Or buy a wet kit. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ...Hope this helps.
<small>[ October 20, 2002, 04:15 PM: Message edited by: PewterZ ]</small>
Old Oct 20, 2002 | 11:10 PM
johnster's Avatar
thanks man
Old Oct 21, 2002 | 09:04 PM
PewterZ's Avatar
Yep....Good Luck. Let us know what you do and find. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Tim
Old Nov 2, 2002 | 11:59 PM
johnster's Avatar
Hey guys turned the nozzle up alittle so it would hit the top of the lid.Sprayed the **** out of it last night,it ran good.No codes,ran 7.70 spinning 60's were 2.00. the best was 1.98
